Obd 2 motor into an obd 1 chasis
lsvtecdc2
Post by lsvtecdc2 » December 25, 2006
I have a new motor in my integra the motor is obd 2 my car is obd 1 the motor came with the engine harness how hard is it to change out harnesses? And whats involved?
"Jdm or Nothin"
Post by tenchu » December 25, 2006
When I put an OBD2 motor in my OBD1 Civic I just converted the motor to OBD1. Should be easy if your going from a B-series to another B-series. Just take all the OBD specific parts off your b18 and put it on the new motor.
mcmBuilt
Post by mcmBuilt » December 25, 2006
tenchu wrote:When I put an OBD2 motor in my OBD1 Civic I just converted the motor to OBD1. Should be easy if your going from a B-series to another B-series. Just take all the OBD specific parts off your b18 and put it on the new motor.
YUP..............OBD1 distributer, injectors, alternater, ecu, etc................
bklyneg
80% ricer
Post by bklyneg » December 28, 2006
fuck that just re-pin everything.
clean cars and dirty sluts
JDMJedi
Post by JDMJedi » December 28, 2006
Ok stupid question: What does OBD1/2 stand for and what is the difference??
2003 Honda Civic SI - Time to get to work.
CivicSpoon
Post by CivicSpoon » December 28, 2006
On Board Diagnosis. Basically the OBD2 systems look for more things (sensors) than the OBD1 systems do, so they can control emissions better.
Some of the wiring is different; different alternator plugs (you can swap the voltage regulators though), injector wiring is backwards (colored wires to yellow, yellow to colored wires), there are 3 different distributor plugs (obd1, obd2a and obd2b), some engines have 2 O2 sensors while others have 1, plugs that hook into the ECU are different from OBD1 to OBD2, OBD2a and OBD2b ecu plugs are the same but the wiring is completely different, extra sensors for the OBD2. Most of that info is for Civic's and Integras, but it should be similar from car brand to car brand.
JDMJedi
Cool I didn't know. Thanks for the info
Post by Nikku » December 29, 2006
JedixA wrote:Ok stupid question: What does OBD1/2 stand for and what is the difference??
for reference
89-91 OBD-0
92-95 OBD-1
96-99 OBD-2a
00+ OBD-2b
i havent checked up on recent cars to see if they are still on OBD-2b or what so i just put 2000+, but that gives you an idea of when things were changed
Andrew EH2
90% ricer
Post by Andrew EH2 » December 29, 2006
Ya nikku your right, my evo is "Obd 2b" supposedly, but i dont see anywhere that marks it
Post by tenchu » December 29, 2006
The reason for the OBD2 (B) change was so that every single car manufacturer all had the the same diagnostics basics. Thats why OBD2 cars get plugged in at the DMV for those of you who have emissions, because pre-obd2 every manufacturer had a differant plug (gm, ford, honda, etc), now they are all using the same one.
