Koni install...Cutting stock housing...? *help*
Cascino
Post by Cascino » July 07, 2005
Has anyone ever had to cut 40mm off of your stock strut housing to get the Konis to fit?
Post by .saint » July 07, 2005
weird.
Cascino
ya its an em thing...u have to cut 40mm off the top of it, take out the factory struts(internals) and drop in the konis.
tommybanzai
25% ricer
Post by tommybanzai » July 08, 2005
talk to ihavemorecarbonfiberthanyou (or however you spell that) , he would know. i never heard of that before...and i'd be 100% sure before i started hacking
Post by .saint » July 10, 2005
yeah i agree with tommy but your not going to be able to get ahold of knepper no more thanks to his 10+ 'hi' posts he is gone. i dunno what his deal is..
i never heard of cutting a strut before and honestly that dont sound right at all koni makes parts that are direct plug and play. if it involves cutting a strut or spring or anything of the sort i think you got a wrong part. expecially if it says 40MM and not like... 1/4 inch or something.
Post by munster » July 11, 2005
I never heard of cutting them. I wouldn't actually. As far as I know Knepper is still on stock anyhow. Just springs. For the reason that no one had struts made for the car at the time.
mr.green
80% ricer
Post by mr.green » July 13, 2005
The Koni's are inserts for the original housing.... and are over priced as well for what you get. I've had Both Koni's and Tokico's and the later are much better IMO. Plus the Tokico's in this application come with the complete assembly brand new. You do have to cut/grind/dig out the factory cartridge. Send them back and buy tokico's. I have a lot of experience in EM chassis and used tokicos on them, very nice.
My car is cleaner than your ass.
Cascino
Post by Cascino » July 17, 2005
awesome, thank green :up:
ls.pwrd.hb.
75% JDM
Post by ls.pwrd.hb. » July 17, 2005
thats weird as hell
low n slow
centurioncivic
Post by centurioncivic » September 27, 2005
yes that is right about cutting the strut housing. I know someone that did it and said its a big hassel and they have the tendency to rattle around once you drop the kponi down inside the stock strut housing. you must do this because koni didnt make the struts with a control arm(?) the arm thing that conects to your tie tod end, therfore having to use the stock. make sure you measure twice and only cut once because you dont wanna fuck it up.
