Removing auto tranny out of a DA?
second generation integra. [90-93]
98exploda
Post by 98exploda » January 08, 2004
I need to take my auto tranny out so i can get ready to put my manual tranny in and i don't know everything or where stuff is connected. So what do i need to remove? the locations of things would help too? Im about to remove the CV shafts. I've already drained my radiator, pulled the battery, intake, battery tray, 2 ac lines, front wheels, and plastic piece underneith along with everything on the interior that's in the way of the auto shifter which still needs to be dropped out. Anyone know exactly where the starter is at? cuz i need to pull that out too.
EDIT: well i have to wait to buy or borrow a 36 mm bolt cuz i seem to have every bolt size but that 1. I may just have to wait for my friends to come over and help because they have more experiance then me 8)
98exploda
anyone?
Post by .saint » January 08, 2004
munster did a tranny removal/install in the how-to section i think.. check it out.
DA 9_Chinga
Post by DA 9_Chinga » January 08, 2004
yea munsters tranny removal how-to should help you out some what just check it out like fone said,
g2JDMteg
Post by g2JDMteg » January 09, 2004
i think the starter is on the intake side of the motor, and if your looking at your distributor it should be a little farther back and down. thats where it is a on 5 speed trans, not to positive if it is the same.
Team 1320
98exploda
Post by 98exploda » January 11, 2004
thanks guys. I finally got the starter out. Both bolts were facing the same direction towards the motor away from the passenger side. I had to buy a swivel socket to get the one on the bottom out and it still took an hour! Now im gonna go check out that how to and see what else i can take off the tranny that won't be to hard to do. I just got my exedy stage 2 clutch kit and type r shift knob in to :-D
Post by .saint » January 11, 2004
RedG2integra wrote:thanks guys. I finally got the starter out. Both bolts were facing the same direction towards the motor away from the passenger side. I had to buy a swivel socket to get the one on the bottom out and it still took an hour! Now im gonna go check out that how to and see what else i can take off the tranny that won't be to hard to do. I just got my exedy stage 2 clutch kit and type r shift knob in to :-D
congrats. take pics :) i wanna see this beotch.
Post by munster » January 11, 2004
I'd take the whole shebang out of the car. It's so easy to remove the tranny when the motor is on the floor.
If I remember correctly there are like five bolts on the tranny towards the motor and two or three (maybe more) facing the tranny. Getting the tranny to slide off of the dowels is going to be a bitch if it's in the car. You also have a few clips to undo.
DA 9_Chinga
Post by DA 9_Chinga » January 16, 2004
if you want i could print out a high-detail (quality) removal and installation. I have a program at my Auto Mech. class called ALL-DATA its the greatest thing ever created. It has pictures along with step-by-step instructions. If you still need it let me know im their everyday.
~DA9~
98exploda
Post by 98exploda » January 18, 2004
I think my friend is going to bring his DIGI CAM over today and we are going to take pictures of new parts going into the car for the swap and pictures of the engine bay with how it's all stripped right now. my baby looks so dead right now cuz alot of shit is stripped off. And Chinga that'd be tite if u could make that how to for me. You can e-mail it to me at [email protected] if u want. Here's a list of mods going into this swap.
*Exedy stage 2 clutch kit
*ACT flywheel 12.5lbs
*B&M short shifter
*Type R shift knob
*Type R e-brake boot
*Type R shift boot
*B18A 5 speed tranny
*91 shift linkage w/ es bushings (if the guy ever ships it out :[)
*91 clutch pedal assembly
total amount spent... $952.64
And then i bought JDM 1 piece headlights for 137.50 or something like that off e-bay to replace my stock OEM USDM headlights that got smashed
Still need a CF hood, and a bumper reinforcement then i gotta get my core support straightend.
I'll keep you guyz updated :)
