Lexan window questions.
Post by 77 » April 23, 2006
Has anyone any experience with this? I'm reading what I can find but I'm still not confident enough to go forward with it. I'm planning to replace my rear 1/4 windows with Lexan. Mounting my fuel cell behind the front seats (where the rear seat should reside but isn't) and having a flush fuel door mounted directly to the glass on the right side (as seen done on the Norris Designs Evo IX coupe.
Any and all tips are welcome and appreciated.
I♥CarFriends!
Secret Squirrel
Post by Secret Squirrel » April 23, 2006
i thought u were goin to do duel filler necks on either side so u never have to remember which side its on
taylor
45% ricer
Post by taylor » April 23, 2006
Secret squirrel wrote:i thought u were goin to do duel filler necks on either side so u never have to remember which side its on
that would be awesome, also teh lazy!
_taylor
Prok0
35% ricer
Post by Prok0 » April 23, 2006
Go gangster man, notch the spare tire well and mount the fuel cell there, like so Image Then just run the filler in the middle of the trunk inbetween the tails.
S14.. Currently motorless.
I will be, no reason to complicate the responses I get with that though.
Prok0 wrote:Go gangster man, notch the spare tire well and mount the fuel cell there, like so Image Then just run the filler in the middle of the trunk inbetween the tails.
I was going to do that, but realized that my fuel cell will fit nicely behind the driver's seat. Also, with the lexan windows I could have my filler neck like Taniguchi's HKS S15 was. Or as seen here in the Norris Design's Evo IX.. Image (Couldn't find a picture of the old silver and black vinyled HKS S15.)
Plus I'll then have a super deep trunk for tires/tools/sandwiches/etc. when track time comes. :wink:
taylor
45% ricer
sounds good, either way will work fine
taylor wrote:sounds good, either way will work fine
Exactly.
I am looking for tips from people who have worked with Lexan. Any opinions welcome.
sikblugsx
75% ricer
Post by sikblugsx » April 23, 2006
sorry to get sidetracked but you will need a firewall between pass compartment and fuel tank and when cutting lexan use a fine tooth blade and use some kinda tape on both sides
sikblugsx wrote:sorry to get sidetracked but you will need a firewall between pass compartment and fuel tank
Yes, that's part of the plan.
sikblugsx wrote:and when cutting lexan use a fine tooth blade and use some kinda tape on both sides
Thanks for the tip.
Prok0
35% ricer
Post by Prok0 » April 24, 2006
I dunno, it seems like if you made the filler in the lexan window you would have to make some supports for it as well, because the lexan will bend when you put pressure on it...
Especially if you were daily driving the car and were filling up regularly...
I would say just throw it in the rear and just run it from the stock filler tube position, cut that out and then run a new one to the fuel cell maybe..
