-mini me- build up
prohonda16
-mini me- build up
Post by prohonda16 » March 24, 2006
i know i'm not suposed to post here as i own an ef.........haha
i do have a question; ready i'm biulding a d15b7 W/d16y8 head.....mini-me as you are all familiar with this swap. it will be turboed; a small t25 on an expected 6-7lbs o-boost. my q is i have never built one and i have an oppurtunity to build 2 one boosted and the other n/a. I need all the tech data that can be thrown at me as i need to get my learn on about these swaps. so any help would be great. i know you guys are out there so hook a brother up with some reading lit.
thanks
steve
i need to stop braking things
CivicSpoon
Post by CivicSpoon » March 24, 2006
mcmBuilt
Post by mcmBuilt » March 24, 2006
spoon man to the rescue :D
CivicSpoon
That's what I get for being a link whore.
Post by hondalowlow » March 24, 2006
i was running a y7/y8 mini me turbo. but it was OK then i put the y8 blovk abck toghter and now i got a whole y8 engine with a 14b turbo and its quick as shit. so maby its the y8 engine or maby its luck but i have shitty luck wiht thew y7/y8 mini me's but i hear that the b7/y8 mini mes are good. get a z6 intakemanifold and install on it. and gewt the d16a6 pistons for your build up. higher compresson and that engine will scream.
Post by boostjunkie95 » March 24, 2006
d15b7 rods = really weak....prolly 170-180whp is all you'll be able to squeeze on a good tune before they start bending and breaking. Im not positive but i dont think they make aftermarket b7 rods, if they do they are like atleast $600-$700....thought i read that somewhere but i cant remember for sure.
Sohchonda5221
75% ricer
Post by Sohchonda5221 » March 24, 2006
i have lots of d16 parts for sale if intrested PM me or IM me on Mooseman0
prohonda16
Post by prohonda16 » March 25, 2006
thanks for the link. i need to read into that site some more. but i doo have one question. if i'm using a 1.5 block and i want to use the 1.6 rods and pistons; i have to ofcoarse bore the block but what about the crank can the 1.5 crank work with the 1.6 rods. i know its a stupid question but i had to ask. and about the CR what would that be at. i need a clue so i know were i'm at for the boosted one. the all motor one i think i might do some actual math on that one and shove some b-block shit into it. just a thought.
steve
2.SloEK
70% ricer
Post by 2.SloEK » March 26, 2006
i dont like the mini me at all!! this kid i know has one and got beatin by a 92 DX coupe he has intake and exhaust. the mini me was in a crx with headers, exhaust. intake, cam gear and a few more but cant remember. eather stick with nonvtec or get the full Y8 or Z6. for the n/a, non vtec with a cam is like vtec all the time
Achilles
Post by Achilles » August 10, 2007
Vtec all the time... that would just be plain retarded. Vtec is a compromise between having a semi good bottom end power band and ridiculously strong top end. Without Vtec you can only have one or the other, so most Non-Vtec cams, are only good for Mid-range RPM power compared to Vtec.
