building a 2.3 stroker
eclipse. galant. diamante. fto. lancer. 3000gt. mirage. etc...
sikblugsx
75% ricer
Post by sikblugsx » November 12, 2005
anybody out there have one? know anybody with one?
tommybanzai
25% ricer
Post by tommybanzai » November 12, 2005
I know of two guys building them at the present time. One is going to be a winter car, and the other ripss up the streets by this race strip near pete's tavern in a little town in western PA. If you want i can give you their contact information so you can talk to them about it.
the new and slightly improved...don't piss me off, and i won't f#*k with you!!! *gggrrrr*
idreamidrive
Post by idreamidrive » November 12, 2005
best bet is to go to a dsm board
Signature
nonJDMdsm
60% ricer
Post by nonJDMdsm » November 18, 2005
what do you want to know?how to build it or just who has it. a lot of the time people run them and dont say anything about it.
http://www.hybridynamics.com
"your either with us, or behind us"
sikblugsx
75% ricer
Post by sikblugsx » November 22, 2005
just curious if anyone on here had one I already have most of my parts for mine, just need to have the block bored and buy valves and springs
sleepinonacreeper
80% ricer
Post by sleepinonacreeper » November 23, 2005
they suck :wink: j/k watch which rods you use. some hit the bottom of the cylinder and sqiurters, some hit the main cap bridges. i had 1 set hit elsewhere in the block by the balance shaft (manley i think). it depends on the design of the rod. (beam and rod cap thickness) you'll have to assemble, find where they hit and remove material from the block. my 2 cents from experience.
Post by BRYCE » November 25, 2005
sounds like a intresting idea, would produce alot of torque. we are talkin about a b series right??
edit: ha i am so honda crazy!! but yea that would still yeild alot of torque from a DSM as well
evodrivesme
Post by evodrivesme » November 01, 2006
if your stroking the motor why do you need to have your block bored? stroke is up, bore is out, so are you 2.3l stroker or 2.3 bore kit?
Post by kotomile » November 01, 2006
I'm guessing without the cylinders bored a little the rod may strike the bottom of the cylinder after the stroke is added?
Just a guess.
evodrivesme
well it shouldnt. Because you get a new crank with the kit, the crank size is different which should change the rod stroke angles.
