b20b vs b20z
Post by Sean @ NDF » October 15, 2005
if your using nitrous you want lower compression
Post by Nikku » October 16, 2005
banzai wrote:if your using nitrous you want lower compression
i disagree, i think keeping the compression the same or setting it at about 10:1 would be perfect, with the proper tuning of course
Post by Sean @ NDF » October 16, 2005
why? its safer to run lower compression
ls.pwrd.hb.
75% JDM
Post by ls.pwrd.hb. » October 16, 2005
true but tuned it would be safe and perform somewhat better
low n slow
ls.pwrd.hb. wrote:true but tuned it would be safe and perform somewhat better
exactly, same applies to turbo/supercharged, yes its safer to run lower compression, but on a boosted motor with lower compression you will have more lag and not necessairly make more power then a higher compression motor running lower boost. both tuned properly of course
Hercules
50% ricer
Post by Hercules » October 28, 2005
arent the b20z's harder to find because theyre newer and only u.s.? i'm pretty sure the jdm b20 is the same as the usdm b20b, just get the B, its easier to get. and probably cheaper too, and just use your stock civic harness with the ls ecu and intake manifold
embidia1
thanks
Post by embidia1 » October 28, 2005
thanks for your help...
