OBD1 and OBD2?? whats the difference?
astroxtc
Post by astroxtc » February 15, 2005
so what is the difference between the OBD1 and OBD2 ecu's??
Post by munster » February 15, 2005
The main difference other than plug differences, etc. is that obd2 has two O2 sensors. The ecu pulls information from the first sensor and checks it with the second sensor. Pretty much to see if the catalytic converter has failed or is missing. obd2 also has a taddle tell system.
Hercules
50% ricer
Post by Hercules » February 15, 2005
yes and and there are different kinds of obd 2's like 96-98 is obd2a and 99-01 is obd2b someone correct me if i'm wrong
Dc2gsr95 wrote:yes and and there are different kinds of obd 2's like 96-98 is obd2a and 99-01 is obd2b someone correct me if i'm wrong
That seems right unless I'm wrong. I thought 2b was up to 00 and 01 and up has some other version of obd2.
phan
40% JDM
Post by phan » February 16, 2005
i'm with munster, i'm sure 00+ is 2b.
jdmhatch21
Post by jdmhatch21 » February 17, 2005
also ob2 has to be hooked up to a computer to read codes. No more flash codes. OBD2B is 00+.
astroxtc
Post by astroxtc » February 18, 2005
so what is perfurred? better?
Post by tenchu » April 16, 2005
Neither is really better. The only advantage to OBD2 over OBD1 as far as I know is the fact that every car has a univeral plug, weather is GM, FORD, HONDA, or NISSAN, the government made it manditory that all cars had the same diagnostics plug to make it easier on mechanics. Cars that come with OBD2 are a little pickier usually, ie: if you remove a catalytic converter in your car it will throw a code to your ECU, and usually toss the C.E.L. and the emissions testers will be able to see that when they plug it in, though there are ways to bypass that also (like we did in the WRX).
Post by Sean @ NDF » April 17, 2005
Munster pretty much explained it in his first answer...
OBD = On Board Diagnostics, aka your emissions controller if you will...
I converted my 00 si to obd I because of the ease of tuning an I car over the stock II. But it is illegal if you live in my state :down:
Post by munster » April 17, 2005
I converted mine to obd1.
It's not illegal in PA...yet.
