duckbill wing install
Hatcher
85% ricer
Post by Hatcher » February 02, 2004
I'm trying to take off my stock brake light spoiler so i can install a vis duckbill wing. so far i've taken out the 2 little screws where the brake light is and the 2 nuts underneath in the door jam... what do I do next? thanks
Post by .saint » February 03, 2004
open the hatch and look in the center there should be a black plug. take that plug out and there is a bolt hiding under there. undo that bolt and the rest of the bolts. and it will pop right off.
Post by tenchu » February 03, 2004
and dont forget to post pictures when complete :grin:
iron monky
Post by iron monky » February 03, 2004
to install a duck bill wing you need to
a.disconnect yur factory tail light
b.undo the water plugg
c.pull of the upper center panel and reviel 2 bolts
d.unscrew the outer bolts...in total there are only 4 bolts
e. remove and place yur new duckbill on yur car
florida is a bright state, not the people.
Post by BRYCE » February 03, 2004
f. sport it around town
Hatcher
85% ricer
Post by Hatcher » February 04, 2004
well I got it installed and the fitment turned out to be good. But now I have a couple more questions... I installed it like I said but I didnt disconnect my tail light to do it, and I didnt do anything with that plug that john mentioned. all I did was wrap electrical tape around that wire thing that goes into the little tube. and off to the right there's that little wire plug harness I diconnected that when I took off the stock one and I wrapped that in electrical tape. Is there anything I should've done differently?
iron monky
Post by iron monky » February 04, 2004
as long as u wrapped the wires up and there not exposued then you shoul be ok man
Hatcher
85% ricer
Post by Hatcher » March 15, 2004
next step... get a real spoon tail. I've learned my lesson with this fake shit. VIS wings suck, my friends hood has a 1/2 inch gap above his right side headlight too, I think I'll only get their c/f hatch and that's it.
