After all this time.... Zero's build BEGINS!!!!
Re: After all this time.... Zero's build BEGINS!!!!
well due to money issues i needed to sell the rims sooner then later so i settled with they guy and a semi ripped lip. it just needs to be either bondoed or fiber glassed together is all really. i got more money then i was asking for because the lip was busted alittle so it wasnt a bad deal in the end. i dont have pics but i will later.
im debateing on if i should fix the front bumper too and respray it myself along with the lip so its all color matched and new looking. i wouldnt feel right fixing the lip and not trying to fix the bumper so its been on my mind ever sense i got the lip.
its sunny but its very windy and thanks to that the wind chill is in the 50s or lower. it sucks. id rather have snow then wind chill.
I drive a Honda シビック クーペ
"We're supposed to be expressing are own artistic talent and vision through our cars, not everybody else's. Use yours to show the rest of the world who you are... i dare you." - Dru Barrios of Honda Tuning Magazine
started to work on the OEM bumper and the new Si lip by sanding down the areas that need to be fixed. i dont have any pictures atm cause of the lack of a camera atm. i dont care to explain but i will have my camera back soon and prolly with a new lens among the possibility of other things like a flash and tri-pod. hopefully the bumper will be finished with a fresh coat of paint and color matched to the lip. ill be taking my time with this making sure its all perfect and all that. i might even switch to my stock front grille and the stock hood and paint my Si center grille too. ill be also painting my keyless handles too. we shall see if i go that far or not.
door handles being primered
front bumper and Si lip being sanded/fixed/preped for primer O_O
got alittle bored so i cleaned the Mugens
missing 1 lug cover. bummer. ha.
lol i bought them like that for $110 while i was in Japan remember? ill take one missing lugcap and a set of MR5s in that condition anyday.
i remember u buying them in japan super cheap, its been awhile forgot it had a missing lug cap though.
none the less. i would have picked them up as well haha.
some pics of what ive done to fix the lip. ill post pics later when i get some color on it and all that good stuff.
before
vice grips to help keep the tear in place while i fixed it and sanded it down.
after
i did some more work after i took these pics to try and make it look better but you should be able to see that after i get color on it and all that. oh and in that last pic if you look closely you can see on the right some color. thats the door handles O_O
before
vice grips to help keep the tear in place while i fixed it and sanded it down. after
i did some more work after i took these pics to try and make it look better but you should be able to see that after i get color on it and all that. oh and in that last pic if you look closely you can see on the right some color. thats the door handles O_ORe: After all this time.... Zero's build BEGINS!!!!
paint being applied. im hopeing this will be the last of it and i can start applying some clear -_-
lip repair... its not perfect but its much better then before and its not ripped.
getting there homie
