help
Re: help
First thing first you check al your fuses? Reset your ecu?
Re: help
pull the bulb? lol.
ground and everything between the cluster and the harness the same?
Re: help
lol... cmon jon, its the AIRBAG not the check engine light, lol...
you got the yellow plug hooked up to the harness?
Re: help
yeah the SRS light, mines on in my civic because i pulled the entire srs unit.
if the plugs are different on from the accord to the tsx cluster its going to put the light on, its a warning light letting you know the srs unit is not functional.
Re: help
ARE not the fuses cause I put the old one back and the light goes off,how do I reset the ecu?,there is only one big green plug they look the same ,although the jdm cluster has a small plug next to the big one.thanks all for the help
Re: help
the SRS wiring is 99% of the time yellow in all cars. i know in all honda's its yellow. any pictures of the back of the cluster?
Re: help
As Jon said, the SRS plug is 99% of the time yellow, like such:
If you have a small opening, thats probably where the SRS plug goes
If you have a small opening, thats probably where the SRS plug goesRe: help
If your sure its not the fuse, i'd take it to AutoZone and have them scan your ECU for free, then they can reset it for you too.
