**ROBRY'S OFFICIAL BUILD THREAD**
robry
70% JDM
Post by robry » April 26, 2008
Hercules wrote:Its not like he's got an ebay turbo kit..its just a adapter peice.
Make sure that will fit the rsx yo
Have you looked into the sidemount manifolds? I saw a 505 whp 15psi pump gas 05 type s on youtube. Stock internals with a full-race stage 2 = hammertime
I have, cost and installation make it a pain in the ass imo. The revhard manifold can support 500whp with a bigger turbo (sc6169) which is 800$. I don't want to make that much power right now. The one on youtube with the F-R 2GT kit, blew up because the kid ran c16 everywhere and went around a corner and ran lean. Piston melted to the sleeve and the rod pulled outta the piston and destroyed the block. meh. I'd rather run 350-400whp and be safe, than blow a stock block just to make an extra 100whp ;) Anyhow, I'm looking forward to the install and having a decently quick car :)
06' RSX-S Turbo | PTE SC6162S 417whp!
Post by munster » April 26, 2008
~300whp on the street will be a blast.
Can't wait to get dirty on the RSX.
robry
70% JDM
munster wrote:~300whp on the street will be a blast.
haha, its gonna be more like 350whp or so :)
tomoyasu
Post by tomoyasu » April 26, 2008
looks like it will be sick ;)
-1990 Civic Hatch STD with b16a
robry
70% JDM
Post by robry » April 27, 2008
thanks guys... I'm gonna pull the flywheel today and take it tomorrow to get resurfaced. I'm talking to Brian (fade2black) from Clubrsx.com and Tuesday order for all the parts I need. I'm gonna try the boost by gear/boost by rpm function in kpro and use hondata's boost solenoid to see if I can run off the wastegate in 1st and 2nd, but run 10-12 lbs in 3rd through 6th. We shall see what happens. I took some more photos of the tear down as well. Which I've added to the original post.
Post by .saint » April 27, 2008
:thumbup:
robry
70% JDM
Post by robry » April 30, 2008
UPDATES:
parts to order:
THGT3-31 turbine housing (4-bolt .63 a/r) - 229$ + s/h
3" GT 4 Bolt To 3" V-Band Adapter/Flange Turbo - 75$~ shipped
1/2" NPT male to -10AN male - 5$
-3 AN Male to 1/8 in. NPT Male - 3$
Oil sandwich adapter - 50$
Exhaust Wrap, Cool-Tape, Fiberglass Composite, 1 3/8 in. Wide x 15 ft., Self-Adhesive - 14$
metal zipties - 15$~
misc bolts - 20$
750cc RC injectors and plug n' play harnesses - 350$~
custom 3" downpipe (175$ left to pay for labor once its built)
to be done once everything is installed:
get test pipe welded to exhaust: 100$~
pay my friend JD to come down and tune car 150$~ or something
rent 2 hours of dyno time (240$~?)
also, I ordered these parts, and they should be here this weekend:
CC STG4 Clutch
Autometer dual pod
Autometer oil pressure
Autometer boost/vacc pressure
hondata boost solenoid
buddyclub secu timer
walbro 255gph fuel pump
innovative 75A race mounts (didn't do a front mount yet, I'll do that later)
tommybanzai
25% ricer
Post by tommybanzai » April 30, 2008
...egt?
the new and slightly improved...don't piss me off, and i won't f#*k with you!!! *gggrrrr*
TURBevO8
30% ricer
Post by TURBevO8 » April 30, 2008
tommybanzai wrote:...egt?
Wideband? Wish I would've got one instead of my EGT. Oh well.
Great to see the car coming along so well. I will really have to take a walk down Bedford St. one of these days and check this thing out since it wont be at Carlisle as you said.
'04 Apex Silver EVO VIII GSR
tommybanzai
25% ricer
naked lady air freshener? :)
good luck on the build!!
