UPDATE: pg. 2, click here: x
PARTS PURCHASED:
Precision SC6131E .48a/r exhaust (upgrading to a .63)
Revhard Manifold gasket matched
Ebay 5-bolt - 3" Vband adapter
Custom 3" DP with flexpipe and open dump for W/G
TiAL 38mm wastegate with 7.5psi spring
Vortech 50mm BOV
Fast-Turbo oil feed/return lines
Second OEM oil pan to be tapped
MSD 3-bar map sensor and weatherpack
Revhard intercooler and charge piping/couplers/etc
misc vacc line, hoses, blah
fiber heatwrap and silver heat insulation wrap (need more of both probably)
pics here: x
Skunk2 Megapower 76mm ID exhaust
TO BE PURCHASED:RC 750cc high impedance sustained injectors
Competition Clutch Stage 4 RSX sprung clutch
Autometer gauges and pod
Buddyclub Turbo Timer
Hondata Boost solenoid
Walbro Intank HP Fuel Pump: 255lph
Innovative Engine Mount Kit (75A hardness)
and probably some misc stuff I need to buy to make it all work, I'm sure bolts/studs/blah blah blah.
I have some more pics, I already have the transmission outta the car
updated tear down photos here: x
