how long does the 1.6l B6ZE last?
rx7. rx8. mx3. mx6. miata. mazda3. mazda5. mazda6. etc...
idreamidrive
Post by idreamidrive » February 25, 2007
under normal wear and tear how long do these things usually last? what about the 1.8l BP-ZE
Signature
Post by kotomile » February 25, 2007
Generally as long as any good Honda engine. With boost, generally 100k miles @ 12 psi is the norm.
Both the B6 and BP are about the same strength.
Why do you ask?
idreamidrive
cause i found a boosted 91 brg with 194k on the clock and was wondering when it was going to blow, and was just thinking of replacement motors when it does set a piston through the block
Most of the time Miata engines die by just losing compression (rings) and die slowly. A compression check will tell you a lot. Find out if the rear end has been upgraded to a 1.8 or RX7 rear, that's a big weak link, and also ask how much boost has been run through it. Anything under 12 and it ought to be fine. B6s are cheap anyway, if it does need to be replaced.
idreamidrive
he's only running 6psi cause he said anything higher would make the stocklike clutch slip
Yep, that it would. Should be fine then. 6 psi is nothing.
idreamidrive
Post by idreamidrive » February 26, 2007
kotomile wrote:Yep, that it would. Should be fine then. 6 psi is nothing.
good. now i just have to wait till spring break to fly down and pick it up
airbrush1
Post by airbrush1 » February 26, 2007
great, yeah, miata motors are strong..... hard to kill
finally turbo!
Post by kotomile » February 26, 2007
I was wondering if anyone else was going to chime in.. lol.
airbrush1
Post by airbrush1 » February 27, 2007
yeah.... I as waiting a while since I run a 1.8..... but I'm running 12psi with no issues so far..... I've heard that the 1.6's can handle more
