Anyone else using water or methanol injection?
think I am going to be going with Hydramist sometime this spring, in additon to my front mount, I should be able to make 300hp with proper tuning on the stock block.....
finally turbo!
i plan on running something in spring as well .. devils own, cooling mist or snow performance ... just need to look into it a little bit more so i understand it completely before i buy.
I'll also be running it in addition to an intercooler ... probably just using water injectino though - not sure if i'll bump to methanol or a methanol mixture or not. It'll be used more as a safety precaution rather than to make power.
Kotomile, you run the devils own kit, right?
1990 Accord EX Sedan
All stock, All the time
money in the baaaank
Wideopentuning
- 100% ricer
