how long does the 1.6l B6ZE last?
- idreamidrive
under normal wear and tear how long do these things usually last? what about the 1.8l BP-ZE
Signature
- idreamidrive
Most of the time Miata engines die by just losing compression (rings) and die slowly. A compression check will tell you a lot. Find out if the rear end has been upgraded to a 1.8 or RX7 rear, that's a big weak link, and also ask how much boost has been run through it. Anything under 12 and it ought to be fine. B6s are cheap anyway, if it does need to be replaced.
- idreamidrive
- idreamidrive
great, yeah, miata motors are strong..... hard to kill
finally turbo!
check the cardomain!!! http://www.cardomain.com/ride/832854
