I have, cost and installation make it a pain in the ass imo. The revhard manifold can support 500whp with a bigger turbo (sc6169) which is 800$. I don't want to make that much power right now. The one on youtube with the F-R 2GT kit, blew up because the kid ran c16 everywhere and went around a corner and ran lean. Piston melted to the sleeve and the rod pulled outta the piston and destroyed the block. meh. I'd rather run 350-400whp and be safe, than blow a stock block just to make an extra 100whpHercules wrote:Its not like he's got an ebay turbo kit..its just a adapter peice.
Make sure that will fit the rsx yo
Have you looked into the sidemount manifolds? I saw a 505 whp 15psi pump gas 05 type s on youtube. Stock internals with a full-race stage 2 = hammertime
**ROBRY'S OFFICIAL BUILD THREAD**
thanks guys... I'm gonna pull the flywheel today and take it tomorrow to get resurfaced. I'm talking to Brian (fade2black) from Clubrsx.com and Tuesday order for all the parts I need. I'm gonna try the boost by gear/boost by rpm function in kpro and use hondata's boost solenoid to see if I can run off the wastegate in 1st and 2nd, but run 10-12 lbs in 3rd through 6th. We shall see what happens. I took some more photos of the tear down as well. Which I've added to the original post.
UPDATES:
parts to order:
THGT3-31 turbine housing (4-bolt .63 a/r) - 229$ + s/h
3" GT 4 Bolt To 3" V-Band Adapter/Flange Turbo - 75$~ shipped
1/2" NPT male to -10AN male - 5$
-3 AN Male to 1/8 in. NPT Male - 3$
Oil sandwich adapter - 50$
Exhaust Wrap, Cool-Tape, Fiberglass Composite, 1 3/8 in. Wide x 15 ft., Self-Adhesive - 14$
metal zipties - 15$~
misc bolts - 20$
750cc RC injectors and plug n' play harnesses - 350$~
custom 3" downpipe (175$ left to pay for labor once its built)
to be done once everything is installed:
get test pipe welded to exhaust: 100$~
pay my friend JD to come down and tune car 150$~ or something
rent 2 hours of dyno time (240$~?)
also, I ordered these parts, and they should be here this weekend:
CC STG4 Clutch
Autometer dual pod
Autometer oil pressure
Autometer boost/vacc pressure
hondata boost solenoid
buddyclub secu timer
walbro 255gph fuel pump
innovative 75A race mounts (didn't do a front mount yet, I'll do that later)
parts to order:
misc bolts - 20$
CC STG4 Clutch
Autometer dual pod
tommybanzai
- 25% ricer
tommybanzai
- 25% ricer
