help
accord. tsx & crosstour all generations tech.
robopat
help
Post by robopat » September 13, 2009
hey guys I bought a JDM gauges for my 04 accord,by the way if anybody cares the jdm tsx 04-07 gauges are the same as the usa accord,everything works and looks good but the airbag light stays on ,any help on this wuold be great.Thanks.
Re: help
Post by tenchu » September 13, 2009
First thing first you check al your fuses? Reset your ecu?
Re: help
Post by .saint » September 13, 2009
pull the bulb? lol.
ground and everything between the cluster and the harness the same?
Re: help
lol... cmon jon, its the AIRBAG not the check engine light, lol...
you got the yellow plug hooked up to the harness?
Re: help
yeah the SRS light, mines on in my civic because i pulled the entire srs unit.
if the plugs are different on from the accord to the tsx cluster its going to put the light on, its a warning light letting you know the srs unit is not functional.
robopat
Re: help
ARE not the fuses cause I put the old one back and the light goes off,how do I reset the ecu?,there is only one big green plug they look the same ,although the jdm cluster has a small plug next to the big one.thanks all for the help
Re: help
the SRS wiring is 99% of the time yellow in all cars. i know in all honda's its yellow. any pictures of the back of the cluster?
robopat
Re: help
I know about the yellow wire but here is only one harness I`ll get same pictures.
Re: help
As Jon said, the SRS plug is 99% of the time yellow, like such:
Image If you have a small opening, thats probably where the SRS plug goes
Re: help
If your sure its not the fuse, i'd take it to AutoZone and have them scan your ECU for free, then they can reset it for you too.
