2004 accord idle higher
accord. tsx & crosstour all generations tech.
robopat
Post by robopat » May 12, 2010
hey ,I have a problem and I hope someone can help me.I had my car park for 5 month and I didn`t make it run regularly Now is back on the road but the idle is too high and is going up and down ,The gas tank was full .so I use a fuel system treatment and I cleaned the trottle body but i still get the 0507 code for idle higher then normal.With that code I can get the emmision inspection pass.Here in NY they are really tough with that.I hope somebody knows about this.Thanks.
Re: 2004 accord idle higher
Post by .saint » May 12, 2010
so im guessing the idle is fluxuating. its up then its down its up then its down like you are tapping the gas then off it then tapping again real quick? how high is it going?
robopat
Post by robopat » May 13, 2010
it is going between 1&2 after a little bit stays in 2.Do you think pumping the old gas out would help?Thanks.
Post by .saint » May 17, 2010
eh. usually the gas wont have much effect on the idle like that.
i tried looking up the 0507 code but came up with nothing.
have u used the CEL flashing light trick?
http://www.ff-squad.com/technet/how-to/celcheck/
here is a list of CEL codes and obd2 "p" scanner codes. maybe i missed the 0507 code in the list but you can check.
http://www.ff-squad.com/technet/ecu.codes.htm
http://www.ff-squad.com/technet/ecu.codes-p.htm
Jams_ek
Post by Jams_ek » May 17, 2010
its the sensor in your cat mine did it for a long time til I put my spoon sports cat on and my new sensor now its fine... I'd check that first
Post by .saint » May 18, 2010
yeah i was thinking a dirty o2 sensor. its a hit or miss if it will throw a code. if its real bad it will.
Jams_ek
Post by Jams_ek » May 19, 2010
well I didn't know but mine came unplugged lol
