p28 swap...
nizzan1984
p28 swap...
Post by nizzan1984 » August 21, 2007
well i have a p28 and obd1 harness for my d16y7 when i get the turbo on. would it hurt anything if i just put the p28 in for a bit, or would everything go crazy on me? the car has a stock y7 by the way.:cool:
ooo and where is the computer located if i do try it? i can remember seeing it before but now i forget where it was...:banghead:
"God invented turbo lag to give the domestic guys a false sense of security."
jdmcivic98 wrote:Jewish Domestic Market
Post by Nikku » August 22, 2007
nizzan1984 wrote:well i have a p28 and obd1 harness for my d16y7 when i get the turbo on. would it hurt anything if i just put the p28 in for a bit, or would everything go crazy on me? the car has a stock y7 by the way.:cool:
i personally wouldnt even recommend using a P28. i would say stick with your current ECU and get it hondata or chrome modded. but if you are going to use the P28, switching now (with a jumper) shouldnt cause any problems. you wont gain anything from it really now though either. ECU should be under passenger side carpet.
nizzan1984
Post by nizzan1984 » August 22, 2007
Nikku wrote:i personally wouldnt even recommend using a P28. i would say stick with your current ECU and get it hondata or chrome modded. but if you are going to use the P28, switching now (with a jumper) shouldnt cause any problems. you wont gain anything from it really now though either. ECU should be under passenger side carpet.
yea, well the p28 is tuned and the rev limiter was set higher so i just wanted to see if it made a difference. thanks for the help!:mrgreen: any other opinions greatly appreciated!:cool:
mcmBuilt
Post by mcmBuilt » August 22, 2007
It won't hurt anything and it should run a little better.
nizzan1984
mcmBuilt wrote:It won't hurt anything and it should run a little better.
well, i did the swap but when i started it the car it bogged down and stalled if i pressed the gas and the cel also came on. i think the p28 is chipped so i dont know if that could cause the problem with a stock motor?:rolleyes:
Post by Nikku » August 23, 2007
nizzan1984 wrote:well, i did the swap but when i started it the car it bogged down and stalled if i pressed the gas and the cel also came on. i think the p28 is chipped so i dont know if that could cause the problem with a stock motor?:rolleyes:
depends on the "chip". most chips are CRAP.
miyagi
Post by miyagi » August 23, 2007
sounds like the TPS and MAP plugs are reversed ... but you didn't touch them. weird.
1990 Accord EX Sedan
All stock, All the time
money in the baaaank
Natural Aspirations
55% ricer
Post by Natural Aspirations » August 23, 2007
OBDII ecu's cannot be easily chipped
Your problem using the P28 ECU is that it thinks you have a Z6 motor not a Y7, There are 2 important differences.
First the Y7 has 190cc Injectors while the Z6 has 240cc injectors, so its not giving enough fuel.
Second is the IACV the Z6 uses a 2 wire plunger style valve while the Y7 uses a 3 wire rotary valve, the Z6 ecu is not able to idle your car because it cannot operate the Idle Air Control Valve.
Tee
nizzan1984
Post by nizzan1984 » August 23, 2007
well i think the problem is that the p28 that i have is set up to run my dsm 450cc's that i dont have in the car... the car sounds like its getting flooded w/ gas. looks like back to the stockie!
Natural Aspirations wrote:OBDII ecu's cannot be easily chipped
Tee
yeah, that i know, but it can be done. but on a whole i do not condone chipping at all. chips have to be designed around your exact setup. one change, gotta reburn the chip. something like hondata, or chrome since he is going turbo is ideal. and hondata definately does obd-2 ecu's. not sure about chrome since i have never researched them but everyone at H-T says chrome is some good shits as well.
