OBD1 and OBD2?? whats the difference?
so what is the difference between the OBD1 and OBD2 ecu's??
The main difference other than plug differences, etc. is that obd2 has two O2 sensors. The ecu pulls information from the first sensor and checks it with the second sensor. Pretty much to see if the catalytic converter has failed or is missing. obd2 also has a taddle tell system.
jdmhatch21
- 100% ricer
Neither is really better. The only advantage to OBD2 over OBD1 as far as I know is the fact that every car has a univeral plug, weather is GM, FORD, HONDA, or NISSAN, the government made it manditory that all cars had the same diagnostics plug to make it easier on mechanics. Cars that come with OBD2 are a little pickier usually, ie: if you remove a catalytic converter in your car it will throw a code to your ECU, and usually toss the C.E.L. and the emissions testers will be able to see that when they plug it in, though there are ways to bypass that also (like we did in the WRX).
