shifter problem
MR.G
shifter problem
Post by MR.G » May 12, 2007
ok here's the deal. I have a 93 ex coupe with a b16 swap I also have a b&m short shifter.
The problem- my shifter has been smooth for the year or so that its been in, over the last couple weeks when I drive and the car warms up the shifter gets noticably stiffer to a point where it tough to shift. when the car cools down its back to normal. any idea what would cause this?
DSRacing
Post by DSRacing » May 12, 2007
well to be honest short shifter is trash to me mine came off back in 2002 bad for the tranny i think so take it off and check the shift linkage well your down there
jdm delivery
Post by jdm delivery » May 12, 2007
look at the bushings maybe
Franchise :ninja:
Post by Sean @ NDF » May 12, 2007
yeah, check out the bushings or linkage
Post by Secret Squirrel » May 12, 2007
check bushings and linkage and also use chassis grease to lub shit.
tobytuneds moms civic SI is the exact same way.
MR.G
thanks for the info. a couple weeks ago I checked the bushing, it lookid fine so I put it back in with a coat of lube. also what should I be looking for on the linkage. it seems to happen only after driving for longer periods and when the car is warm.. soon as it cools, its back to normal.
Natural Aspirations
55% ricer
Post by Natural Aspirations » May 12, 2007
Check the Hydraulic system, I am willing to bet its the culprit. Have you checked your trans fluid recently?
Post by .saint » May 13, 2007
Natural Aspirations wrote:Check the Hydraulic system, I am willing to bet its the culprit. Have you checked your trans fluid recently?
i was thinking fluid as well.
MR.G
Post by MR.G » May 13, 2007
ill try the fluids, its a pretty fresh swap and all fluids were replace with new but its worth a shot. thanks again guys
Natural Aspirations
55% ricer
Post by Natural Aspirations » May 13, 2007
have you bled the master cyl?
