its time for bigger and bigger things now!
so yea heres the ma'ma jamin list.
all prices are OBO
Shell
Clean Title.
1993 Nissan 240sx (no Mutha Fuckin Rust) florida car.
Custom Roll Cage ( X door bars, reinforced rear X, DOM tubing)
Origin Aggressive Aero Kit
Origin 20mm Front Overfenders
Origin 50mm Rear Overfenders
3 Week Old Custom Candy Green Paint with Heavy Gold Pearl
Welded Diff
Custom Zip tie stichin
Flame Boy Decal
those will be the only after market things coming with the shell, everything else will just be stock replacements. so it WILL be a ROLLING SHELL.
drop a motor and go!
asking $4500 pretty negotinable on this cause i know it will be hard to find a buyer for. but the aero is worth this alone!!! hahah
Engine.
1998 180sx Type X Sr20det. Very low miles. (Engine, while in japan was driven by a woman, found lipstick and fruity shit in the glove box.) Everything thing you need for complete swap, Engine, Trans, ECU, etc.
$3,000
TurboXS Boost controller
$50
Greddy Down Pipe
$75
Custom Greddy mid mount intercooler.
$500
Blitz BOV
$75
3” Test Pipe
$50
3” Custom exhaust (bozo)
$100
Sr Koyo radiator
$150
FAL E-fans
$150
Walbro 255 Fuel Pump
$50
B&M short shifter
$100
B&M power steering cooler.
$50
Interior
Sparco Speed Racing Seat (Driver)
$250
Sparco Fighter Racing Seat (passenger)
$250
(2x) R.J.S. Hot pink 3” Camlock harness
$100 bucks each.
Nismo Dildo Shift Knob
$30
Autobacs PiNk Steering wheel
$150
Custom Wire harness with Painless 6 Switch Rocker Switch panel and ARC fusing subpanel. Can be made to work with any chassis if you wanna get rid of your cluster fuck of stock wires~!
Full setup for...
$300
Autometer Water Temp
$20
Autometer boost gauge
$20
Exterior
Origin FRP Hatch Wing
$100
6000k HID with H4 conversion w/ citylights
$150
JDM kouki 180sx Tail lights
$350
Footwork
Stance GR+ Pro’s (as good as new, used for 2-1/2 months!
$1000
Garage Spec Tension Rods
$100
Cusco Front and Rear upper Strut bars.
$100 bucks each
Peak Preformance RUCA’s
$200
Peak Preformance Front 5lug conversion hubs.
$275
S14 5lug rear hubswith Nismo 60mm extended studs
$200
Buy them together get em both for $425 save $50!
Driveshaftshop.com Steel one piece Drive shaft
$250
Q45 Break Up Grade
$250
Power Slot Rear Rotors & Hawk HP Rear Pads
$150
Open End Gorrila Lug nuts
$25
Volks White TE37’s
Front 17 x 9.5 +12 with Fed’ 595’s (like new)
Rears 18 x 10.5 +15 with Kuhmo SPT’s (one 18"er is curbed up pretty good for about half the rim, due to my stupid ass...)
$1800
Drift_line Slip on 15mm spacer (4 & 5 lug)
$50
Kics bolt on 15mm spacer (5lug)
$100
Kics bolt on 25mm spacer (5lug)
$100
again i am pretty negotianlble (i suck at spelling) on bigger items but smaller ones, just pay what i have cause its already a good price for moderatly used parts....
here is pics of my car, some items can be seen some cant, some dont need to be seen etc.
thanks.Contact info.
EMAIL is prolly best seein as how this will be on many forums.
[email protected]
AIM = blaster834
Cell = 612-310-6553
