1st time at the dyno
SikofFalln
Post by SikofFalln » March 18, 2003
hit 125.3hp and 95.4tq at 7200rpm.
This was with a B16A2 with a hiper exhaust, race cat, AEM cold air, and a DC 4-1 header while running on a stock unchipped P28. It was better then I thought it would be with the ECU being stock and all. My A/F is really shitty before it hits V-tech.
3-1-4
domoMKIV
70% ricer
Post by domoMKIV » March 18, 2003
those numbers seem pretty low for being modded.....
vtec ;)
http://www.shatbox.com
95 Supra TT
97 Civic Hatch
SikofFalln
Modded yes, but running a stock SOHC ecu on a B16.
MagillaGorilla
Post by MagillaGorilla » August 07, 2003
Get your AFR straightened out and you will make a bit more hp/ft.
Or buy a LS block, yummm. :2:
mugen85r
Post by mugen85r » August 07, 2003
b16a2 makes
160 @7600 rpm
so if you put in the b-series ECU for this engine, what numbers do you think you'll get???
that's a pretty big loss at the wheel for the SOHC ECU
MagillaGorilla
Thats at the flywheel. You lose so much Hpgoing thorugh the drivetrain and wheels its crazy. Iv seen wrose numbers come from a b16 so atleast hes doin somethign right haha. :P
Post by munster » August 07, 2003
Does anyone know what the hp difference would be if he ran a GSR ECU?
MagillaGorilla
It wouldnt be too much. Maybe 5-10 HP max, the Vtec crossover is probably lower too.
Turbogixxer
Post by Turbogixxer » August 07, 2003
I think that you will gain more (than people think) by a chipped p28, or a p30, p72. You car is probaby running lean. BTW did you scan the dyno sheet?
sal_blkej2
Post by sal_blkej2 » August 08, 2003
wrd, get your p28 chipped then dyno it to see exactly how much you gain...i'm interested to know cuz i have a friend with the same mods as you except he has the skunk2 chip on his p28...lmk and good luck
