2006 civic si info
eighth generation civic tech. [06-11]
2006 civic si info
Post by Sean @ NDF » January 16, 2006
Just a few facts from the Honda website
197-horsepower 2.0-liter K20
Engine Type - In-Line 4-Cylinder
Engine Block/Cylinder Head - Aluminum-Alloy
Displacement (cc) - 1998
Horsepower @ rpm (SAE net, Rev 8/04)* - 197 @ 7800
Torque (lb.-ft. @ rpm) - 139 @ 6100
Redline (rpm) - 8000
Bore and Stroke (mm) - 86 x 86
Compression Ratio - 11.0:1
Valve Train - 16-Valve DOHC i-VTEC®
Stainless Steel Exhaust Manifold - Standard
Multi-Point Fuel Injection - Standard
Drive-by-Wire Throttle System™ - Standard
Front-Wheel Drive
CARB Emissions Rating - LEV-2
Direct Ignition System with Immobilizer
100,000-Miles-or-More Tune-Up Interval†
TRANSMISSION
Close-Ratio 6-Speed Manual Transmission
Helical Limited-Slip Differential
BODY/SUSPENSION/CHASSIS
Unit-Body Construction
Control-Link MacPherson Strut Front Suspension
Reactive-Link Double Wishbone Rear Suspension
Stabilizer Bar (mm., front/rear) - 28.0 (solid) / 17.0
Power-Assisted Rack-and-Pinion Steering - Electric
Steering Wheel Turns, Lock-to-Lock - 2.65
Steering Ratio - 13.62
Turning Diameter, Curb-to-Curb (ft.) - 35.6
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes - 11.8 / 10.2
Wheels - 17" Alloys
All-Season Tires - P215 / 45 R17 87V
Michelin® Pilot® Exalto® PE2™ Summer Tires P215 / 45 ZR17 91W
Available
Compact Spare Tire
06fg2
Post by 06fg2 » August 09, 2007
DBW FTL....:(
