im just pulling this post from my website [ http://www.frightmarestudios.com ] [ http://frightmarestudios.com/?p=484 ] figured someone on here could put this to use and save some $ as well. im going to be posting pics asap. [for now im using the stock photos from the efx site.]
never used (out of the package but never used) EFX-TEK started kit + extras.
here is the basic stater kit as described on the EFX-TEK website [ http://www.efx-tek.com ]
link to actual item [ http://www.efx-tek.com/topics/prop-1_starter.html ]
also included with my sale is the PIR motion sensor. USB-to-serial adapter & the 68" PIR extension cable.Prop-1 Starter Kit Description
Are you looking for the things you need to get started with the Prop-1 controller? This kit gives you the essentials; simply connect to your Windows® PC. The Prop-1 Starter Kit includes:
•*http://www.efx-tek.com/topics/prop-1.html - Prop-1 Controller
•*http://www.efx-tek.com/topics/prop-1_trainer.html - Prop-1 Trainer
•*http://www.efx-tek.com/topics/bs1-sa.html - BS1 Serial Adapter
•*http://www.efx-tek.com/topics/serial_cable.html - Serial Cable
•*http://www.efx-tek.com/topics/12vdc.html - 12 VDC power supply
You save 10% over the cost of individual items!
Note to USB users: You should order the USB-to-Serial and cable (below) separately; these products are less expensive than what you'll find at retail stores and are guaranteed to work with our controllers.
PIR SENSOR Description
This PIR sensor from Parallax detects motion up to 20 feet away by using a Fresnel lens and infrared-sensitive element to detect changing patterns of passive infrared emitted by objects in its vicinity. Inexpensive and easy to use, making it ideal for props, motion-activated lighting, and non-critical security applications. This PIR sensor is directly compatible with the Prop-1, Prop-2, and Prop-SX controllers using a standard 3-pin extension cable.
14" extension cable (#805-00035) is included with each sensor.
USB-to-Serial Adapter Description
No serial port on your PC? No problem! This new USB-to-Serial Adapter from our friends at Parallax will allow you program your Prop-1 controller with PC that has a USB port. Simply connect the USB-to-Serial Adapter to the BS1-SA and to your Prop-1. Connect the USB adapter to your PC with a USB A to mini B cable.
This adapter uses the latest FTDI USB-to-Serial adapter chip, the FT232RL, and FTDI provides high-quality drivers that ensure the communications integrity using your favorite operating system.
Note: USB cable is not included with the adapter; it must be purchased separately.
i am running fright idea controllers so i have no need for this EFX-TEK controller.
68" Extension Cable Description
68-inch (5 feet, 8 inches -- 175 cm), three-pin (female-female) extension cable is used for connecting the Prop-1, Prop-2, or Prop-SX to other devices (e.g., the AP-8, DC-16, FC-4, RC-4, Prop-Pot) and pin-compatible sensors (e.g., PIR). Contructed from heavy-guage (#22) wire to ensure good signal strength from end-to-end.
Note: 14" cable pictured -- 65" cable is similarly constructed.
asking: $95 postage paid for the entire package. [at the moment i will not separate]
