[*diy*] ek9 honda civic side marker install.
step by step diy guides.
Post by .saint » April 11, 2010
i do not take credit for this how-to. this is a port from another site, figured it would be a good how-to to have floating around the site.
rvm wrote: You should follow this template:
Image Photo of the placement on the fender, 155 mm from the top of the molding to the bottom of the tape and 140 mm from the edge of the door to the edge of the tape.
Image Find the center of the intersection, which is where the exact center of the sidemarker:
Image Then findd the center of the template and line up the two over each other and tape it down:
Image A drill was used to make the initial hole, then you can use a metal nibbler from RadioShack:
Image Image The final hole:
Image After cutting the hole, add some touch up paint on the bare metal to help prevent rust.
Wiring begins:
Image There are two wiring options. JDM (Sidemarker only blinks when turn signal is on) or USDM (Sidemarkers stay on and blink alternately with the signal).
Pull back the fender liner and remove the corner/parking light. There will be 3 wires going to the bulb. Tap into the corresponding wires for each blinking style.
JDM:
Tap into green(turn signal) and black(ground) wire.
USDM:
Tap into red(parking light) and green(turn signal) wire.
Now side markers are in!
Image Image Image Use this photos to compare with the oem ek9 side markers installed in a EK9. I see them 98% perfect.
OEM JDM EK9 Honda Civic Type R Side markers:
Image Recommendations:
Use a spare fender to test first!
If you don't have patience, don't do it.
Remember to put some touch up paint in the hole to avoid corrosion.
Keep in mind that in certain USA states, and other countries; you can get pull over by the cops if they want because of this modification.
Additional Measurements, just in case you have any doubts:
Image Image
Wax_Hands
Re: ek9 honda civic side marker install.
Post by Wax_Hands » April 11, 2010
Thanks for posting it, really didn't want o have t register for another forum XD
Jams_ek
Post by Jams_ek » April 13, 2010
thanx jon I was lookin for one of these homie!!
