cars not workin
Teaks92HB
Post by Teaks92HB » February 22, 2008
check wires by ecu, maybe even try diff ecu??
tomoyasu
Post by tomoyasu » February 26, 2008
checked the wires, all good. would try a different ecu, but no money to get one and no one around here with one that i know.
Teaks92HB
Post by Teaks92HB » February 26, 2008
so no luck yet??
tomoyasu
nuh uh. my pops just got his volt meter back so we'll go around and check all the electrical shit
tomoyasu
Post by tomoyasu » February 27, 2008
ok, so i may have read the ecu wrong..do you check to see if its throwing codes after turning the key all the way(like when you start it)? or just turn it to 'on'?
cuz when its in 'on' its a solid red light, but goes away after i try to start it
help?
93ludeSi
Post by 93ludeSi » February 28, 2008
your car OBD I right? if your doing the 'paper clip' test then you only have to turn it to 'on'; even accessory i think will work to get the code IF your car is actually throwing a code. also if you replaced the battery it might have reset the ecu so it wont say what code it was throwing before unless it throws the same code again since you changed the battery.
You kinda got me confused though about what your mean about the check engine light turns off after you try to start. kinda sounds like every car where the check engine light is on then goes off after starting(as long as nothings wrong). Also if you have a ecu problem you may not be throwing a code so checking wont give you anything if that makes sense. could probally try and find an ecu on hondatech or something, probally cheapest bet if you end up going that route...
93 Prelude Si H23 VTEC
Post by .saint » February 28, 2008
tomoyasu
Post by tomoyasu » February 28, 2008
its OBD0, first gen b16.
i not getting a CEL, just the light in the ECU stays solid red until i try to start it.
T0DA
Post by T0DA » February 28, 2008
The light is going to stay red until you start it, that's part of the ecu's self test diagnostics that happens everytime you have key on, or key on engine running... If the light stays on once the car is started and running, that's how you know you have a problem.
tomoyasu
ahh, word^ thanks for clearing that up.
