- Administrator
Post
by .saint » October 05, 2004
good luck.
robry
- 70% JDM
Post
by robry » October 05, 2004
we just took my friends axle nut off his dodge 1500 pickup. He had a 10 ft breaker bar on it and it wouldnt budge. Just heat it with a torch, we used a propane torch and that worked. Just heat it up a bit and it should come off.
phan
- 40% JDM
Post
by phan » October 05, 2004
power tools own you! my impact gun makes quick jobs of axle changes...woohoo!
Post
by BRYCE » October 05, 2004
alright good and bad news got that bitch off with some pb and a longer breaker. But i cant get the axel from the hub. i think i need a hub puller?? fuck i dont even now what i need.. blah enough for today i am going back out and putting it back together i got a hot date tonight!! **WINK WINK**
phan
- 40% JDM
Post
gotta pull the lower ball joint out from the LCA first...this can be a bitch as well. once you do get it off, tho, you can push the axle out easily.
Post
Nope... hah i got the ball joint out of the LCA (pretty loose had to for bushing not even a month ago) so ya i dont know why its so tough??
phan
- 40% JDM
Post
ok, take a thin hammer or something and tap the axle out of the hub.
- Administrator
Post
we need ban to start posting here again. he has a trick to getting the balljoint apart real quick.
ban
- 95% ricer
Post
by ban » October 05, 2004
i'd like to give away my trick but i'm to stupid to explain it....sounds like u had no problem with it though... lie phan says all u need to do is tap the center of the axle shaft and it should slide out of the splines. if its rusted and doesn't wanna slide out squirt it with pb.. and get a bigger hammer...good luck
Post
So the threaded shaft that the axel nut was on, thats what i pound out?? Fuck i am soo close
