Hondata intake manifold gasket
Post by boostjunkie95 » February 15, 2007
Has anyone used or is currently using one of these gaskets? I've read they reduce the incoming air temperature by a good amount....is this true or just a bunch of BS? Should i roll with one of these or just go oem Honda?
vtecdood
Post by vtecdood » February 15, 2007
go eith oem honda the only nice thing about them is they are reusalble. I got one for my civic but at the time this is when they first came out afterwards there has been numerous posts on how they do nothing just go with oem.
builtmotorsportswear.com
jdmland.com
Post by kotomile » February 15, 2007
Unless you disconnect everything else heating the IM you won't see much of a drop.
If you want an ice-cold intake manifold, get alky injection :up: My Miata's IM seems to get colder the more I boost lol.
Post by munster » February 15, 2007
+1 for oem gasket.
robry
70% JDM
Post by robry » February 16, 2007
+1 for hondata intake manifold gasket. I installed it awhile ago. Disconnected the tb coolant loop and bypassed that as well. Fucking makes a huge difference on my K. for 50$ you can't go wrong. That and people have dyno proven that it does make a difference. Also, think about how easily you can heat it up at the track while you're idling in the lanes. Soon as you start moving the IM is gonna cool off and you'll have more power. I dunno, when I open my hood after an hour of driving and I can leave my hand on the IMG and its slightly warm, vs before where it would almost burn you, I'm gonna have to say that the IM gasket definitely makes a difference.
06' RSX-S Turbo | PTE SC6162S 417whp!
Post by boostjunkie95 » February 16, 2007
hmmm..... interesting.
Post by kotomile » February 17, 2007
my IM is ICE COLD after boosting up and down the freeway coming home from work.
Methanol - 1
Gaskets - 0
lol :p
phunhaus
Post by phunhaus » March 02, 2007
Fuck the OEM paper gaskets. My IM was considerably cooler with the Hondata gasket (crappy cast AEBS manifold) BUT the biggest benefit is NOT having to scrape off that bullshit paper gasket to work on your car.
Hondata FTW.
I'm not happy unless you're not happy.
Post by Sean @ NDF » March 02, 2007
I have a s2 intake manifold with a plastic gasket and I rule
phunhaus
Post by phunhaus » March 03, 2007
Nah, I have an extrude honed angle milled ITR manifold with a Hondata gasket.
phunhaus rules. :)
