Gauge cluster
- boostjunkie95
Gauge cluster
Id like to pick up a cluster like this for my 5th gen and was wondering if any model came with a 220kph speedo instead of 180. I assume it just plugs right in, correct?
thsy usually plug right in, i know on the 96-00 they do so i dont see a reason why it wouldnt with that, you been sourcing ebay for em?
what is that out of?
- boostjunkie95
- fabricator
All The SIR-I and SIR-II had the 220km speedo but they also had white face and orange neddles...as for a EDM or CDM cluster i'm not really sure. I have a CDM sedan cluster in my 92, but like you said it has white neddles and only goes to 180km....i'd assume that the higher model levels in those years would sport the better cluster. i has been a while since i read up on the clustersboostjunkie95 wrote:Id like to pick up a cluster like this for my 5th gen and was wondering if any model came with a 220kph speedo instead of 180. I assume it just plugs right in, correct?
check with hmotorsonline they always have off the wall stuff like that and they are friendly as hell
- boostjunkie95
- boostjunkie95
