| HID Lighting for Dummies https://thejdm.com/forum/viewtopic.php?f=83&t=7773 |
| Author: | tenchu [ January 22, 2007 ] |
| Post subject: | HID Lighting for Dummies |
Been doing research on HIDs lately, and I thought I would share some of the knowledge I have come across, all typed by me, with a collection of information obtained from multiple sites. What are HIDs? High Intensity Discharge. Unlike your regular Halogen light bulbs, which use a 'burning' filament to produce light, HIDs use Xenon gas, Mercury, and Metal Halide Salt, and are ignited by an arc of high voltage energy provided by a ballast, making them much like a fluorescent light. Temperature (color), and Lumens (brightness) Probably one of the most mis-understood factor of HID lighting is the temperature and lumens. Many people think that the higher temperature(k), the brighter the bulb. This in fact, is un-true, in fact, the higher the temperature, the LOWER the light output is. For example, a 5000k HID bulb puts put 3200lm (lm = lumens) which is more than 3x the light produced by a regular halogen light bulb, whereas a 12000k HID bulb only puts out 'only' 2100lm, which is about 2x the light of a halogen. Still brighter, but not as bright as the lower temperature bulb. Here is a list of temp/lumens. 3000 - Yellow - 3200lm
5000 - White - 3200lm 6000 - Blueish White - 2800lm 8000 - Blue - 2550lm 10000 - Deep Blue - 2200lm 12000 - Purple/Pink - 2100lm Pros and Cons of HID conversions
Pros, for one, they are brighter. And lets face it, they're cooler. But, they can also be a safety hazard to other drivers on the road, and are also technically 'illigal'. Head light housings with Halogen bulbs are designed strictly for Halogen bulbs, to meet the government's standards, and to make the roads safe. HID bulbs produce light totally different from Halogen bulbs, and therefore are not intended for Halogen housings. HID bulbs in a Halogen housing will put out much more light than 'legally' allowed, and in some cases, due to the design of the Halogen housing, will actually blind passengers in front of and oncoming, of an HID equipped vehicle, even when properly aimed, due to the cut-off design of the housing, which is designed for the shorter, Halogen bulb. Low beam only HIDs vs Low/High beam HIDs Deciding on weather or not you should buy an HID kit with just low beams, or a low/high beam kit (bi-xenon) is strictly personal. The majority of us spend most our time driving with our low beams on, therefore the low beam has the most to be desired. I low beam only kit is simpler, and cheaper, therefore best for the HID buyer on a budget. A bi-xenon kit isn't actually 2 bulbs, but an HID bulb with a movable scoop that covers the HID bulb, therefore changing optics of the bulb, to cast as if they were high beams. Thanks for your time, and I hope this helps! Good luck on your HID hunt! |
| Author: | kotomile [ January 22, 2007 ] |
I'd say they're more like looking into a welding arc than a fluorescent light. Fluorescent lighting uses some kind of coating and static electricity. |
| Author: | robry [ January 22, 2007 ] |
true! |
| Author: | tenchu [ January 23, 2007 ] |
I was talking about the Ballast, the arc, my bad. |
| Author: | tommybanzai [ January 23, 2007 ] |
i just got a set of HID's and put them in my car. I have a Scion tC (with 107,000 miles on it). Mine came out fine, and the cutoff point seems ok. I think it has a lot to do with the design of you headlight housing to be honest. i'm kinda tired and don't feel like typing a lot right now. I will later. Here are a few shots of mine. Keep in mind it was snowing and the snow caused some glare...the lights didn't.
***PS: munster asked me to do a write up on my kit/findings etc, and i will in a day or two*** |
| Author: | SingleCamEJ8 [ January 23, 2007 ] |
that HID kit looks sick tommybanzai! |
| Author: | boostjunkie95 [ January 23, 2007 ] |
Looking good Tom. Those parking lots at UPJ are lit up like the 4th of July. |
