customized engine bays. pics. theory. discussion.
Post by .saint » February 02, 2010
the first few posts are a port from the original honda-tech thread.
official honda-tech custom bay thread
official nwp4life custom bay thread part.2
official nwp4life custom bay thread dead.
this thread is honda bias but please report any links or info to me or this thread for your specific car so i can post the information. i will separate the information for quick indexing, im looking to build a totally separate page put together like the rules page in the future with quick jumps for super fast information lookup and navigation.
[img]http://i282.photobucket.com/albums/kk26 ... ct/027.jpg[/img]
mr. coupe
[img]http://i271.photobucket.com/albums/jj12 ... mg7079.jpg[/img]
chase
[img]http://img.photobucket.com/albums/v739/ ... C04553.jpg[/img]
phunhaus
[img]http://i18.photobucket.com/albums/b110/ ... unhaus.jpg[/img]
outdated
[img]http://jsjbrothers.com/albums/album143/ ... Custom.jpg[/img]
mr pho king
[img]http://dut619.com/eibach07/042.jpg[/img]
rywire
[img]http://jsjbrothers.com/albums/album205/ ... Custom.jpg[/img]
eg6aaarrr!!!
[img]http://i161.photobucket.com/albums/t230 ... G_1538.jpg[/img]
ejsex
[img]http://img6.uploadhouse.com/fileuploads ... a58530.jpg[/img]
Important/Useful Links
This is basic “Coles notes” of sites that will aid you in building your customized bay. If you’re currently working on a tuck/shave…these should be bookmarked already
http://cableorganizer.com/
Heat shrink tubing, split wire loom, cable tray, and other cable protection systems and organizers
http://www.svc.com/sleeving.html
This is a computer part site, but great for finding sleeving to cover up your wires.
http://summitracing.com
This site will get you almost anything…from braided lines and fittings to tools, air intakes and motor mounts, etc. This is what I like to call the “walmart of auto parts and supplies”
http://www.anplumbing.com/
The oldest online supplier of Earls AN fittings, adapters, Swivel Seal, Ano-Tuff, stainless steel braided lines, Teflon braided, AN wrenches, AN port adapters, fuel filters, fuel cells, check valves, oil filters, oil block adapters, oil coolers, Setrab, gauge adapters, Turbo line kits, brake lines, brake hoses, you name it.
http://www.markwilliams.com/brakeLines. ... goryID=194
Brake Lines and fittings. The site sells other aftermarket parts, but I believe all you’ll need from this site is brake lines. Their inventory is very nicely organized and has nice big pictures.
http://www.autobody101.com/
Forums, supply lists, DIY’s, videos, etc on auto body and everything you need to know about it to get you going.
https://www.paintscratch.com
One of the best sites to find your paint code for your car, no matter what make or model you own. It’s also great if you want to find a paint code from a car you saw which you want to use for your car.
http://www.hondapartsdeals.com
Excellent part site which provides Honda part numbers, so you can find anything you need. Excellent for those who want to delete their ABS lines finding the part number of those rusty engine bay components
http://www.acuraoemparts.com
Pretty much the same as the Honda part site listed above, except it contains a list of Acura parts.
http://www.parts-express.com/wizards/se ... N=50596263
Great link if you want to clean up and protect your tucked projected with some Braided loom for that great finishing touch.
http://www.fastener-express.com/
This link is provides a lot of bolts washers and nuts which come in many sizes and anodized finishing. Good if you want to replace those old rusty bolts in your bay to match it with the rest of your parts.
http://www.tastynuts.com/
Similar to the link above, but provides a different selection, and these are specified as automotive bolts which are apparently “light weight”
http://www.eastwoodco.com/
unique automotive tools and supplies (everything from rust products, to paint, to powder coating, abrasive blasting, etc…the body man’s heaven)
http://www.waytekwire.com
Waytek Wire usually has lower minimum buying quantities on connectors so you're not stuck buying per hundred. They carry a wide variety of fittings/connectors/loom/shink tubing.
http://www.delcity.net
Automotive battery accessories, fasteners, cable ties, fuses/fuse accessories, grommets, hose clamps, loom and clamps, relays, shrink tube and tape, spooled wire and cable, switches, terminals, trailer connectors, etc. Basically, it’s a great site for all you creative bastards to try new things on your bay with.
http://www.terminalsupplyco.com
They don't list their pricing on their site (which I know can be an inconvenience) but I know if you request a price quote and ask them to beat Del City or Waytek pricing they usually can. Sometimes there are minimum quantities for that pricing though.
http://www.mig-welding.co.uk/
Excellent link if you’re learning how to weld. It’s primarily focused on MIG welders, but as many of you know those are excellent for beginner welders! They provide very useful information on welding new body panels, filling holes, etc.
an lines & fittings:
an plumbing how-to videos:
fire wall grommets:
fuse box grommet: honda part # 91610-sf4-003
[img]http://i50.photobucket.com/albums/f310/ ... G_0654.jpg[/img]
ac hole grommet: honda part # 91631-SR3-000
fuse box/passenger headlamp harness hole: part # 91610-sf4-003
[img]http://i50.photobucket.com/albums/f310/ ... G_2290.jpg[/img]
driver side harness grommet: honda part # 90621-SE0-000
[img]http://i50.photobucket.com/albums/f310/ ... G_2291.jpg[/img]
blocking the coolant ports:
[img]http://i15.photobucket.com/albums/a373/ ... C03017.jpg[/img]
[img]http://i15.photobucket.com/albums/a373/ ... C03016.jpg[/img]
washer honda part # 12209-PR3-000
bolt honda part # 12208-PR3-000
removing harness pins
examples of hard brake lines
Re: shaved. tucked. customized engine bays. pics. discussion.
this is more or less a port from h-t that im tossing together for thejdm so we can all enjoy.
READ BEFORE ASKING QUESTIONS. IT MAY HAVE BEEN ANSWERED BELOW ALREADY!!!
brake lines, fuel lines, clutch line conversions
- converting your fuel line/hydro clutch line to braided w/ fittings
hayce wrote: Is there any write ups out there (like the very helpful fuel line threads :thumbup: :) ) for converting the hydro clutch line to braided w/ fittings?
BoostedJeff wrote: its easy...
(2) -3 to 10mm adapter
-3 line
me and dan did ours with a 3ft line and a 2ft -3 line, with a -3 union in between
SPOON_BeIgHtEeNsEe wrote: or PM Flamenco-T he sells the line and fittings for 75 shipped .... line is 72" long
Also, a VERY resourceful thread for this for those who like pictures: http://honda-tech.com/zerothread?id=1545386
phresh_5 wrote: Fuel system wire harness installed:
[img]http://img206.imageshack.us/img206/5682/dsc00980gd8.jpg[/img]
Brake lines behind firewall (completed). Rear lines are SS untill they go behind the subframe, then they go back to hard lines all the way back. All other lines are SS.
[img]http://img515.imageshack.us/img515/3395/dsc00974kl6.jpg[/img]
[img]http://img511.imageshack.us/img511/1786/dsc00975eg6.jpg[/img]
JDMorgan wrote: all brake/clutch lines are 3/16" line with m10x1.0 fittings, if you want to run an fittings run -3 tube sleeves/nuts. the only brake line not m10x1.0 is the front fitting on an abs master cylinder is actually m12x1.5. it still uses 3/16" line tho.
-NA-aLL-thE-wAy- wrote: I planned on using stainless hardline, but I didn't want to spend a ton of money on the flare tool. Then I decided I didn't like the look of the rear hardlines being inside the car (since the int is stripped) so I decided after I get it dipped I'll redo them with braided.
I have also heard about leakage problems. That's usually caused by the flare being done wrong: either the wrong degree of flare, or the end of the flare cracking do to overflaredness.
I said overflaredness.
SHG_EasyE wrote: some updated pics of mine....
[img]http://i159.photobucket.com/albums/t131 ... 030128.jpg[/img]
[img]http://i159.photobucket.com/albums/t131 ... 030123.jpg[/img]
since so many ppl have asked already this is the list of parts i used off summit racing.
(substitute one -6an hose end for a 45 deg one)
EAR-230206ERL Fuel Filter, Inline Mount, Blue, 85 Microns, -6 AN Male Inlet/Outlet, 1
EAR-581805ERL Fitting, Tube Nut, -5 AN, Aluminum, Blue, Pair, 1
EAR-581905ERL Fitting, Adapter, Tube Sleeve -5 AN, Aluminum, Blue, Pair, 1
EAR-991907ERL Fitting, Union Reducer, Male -6 AN to Male -5 AN, Male, Aluminum, Blue, 1
EAR-991945ERL Fitting, Carburetor Inlet, -6 AN Male to 12mm x 1.25 Male, Aluminum, Blue, 1
SUM-220690 Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue Anodized, 4
SUM-G1001 Hose, Braided Stainless Steel, -6 AN, 18 in. Length, 2
whole setup cost a little under 100 bucks including the new filter
g2_teg_ wrote: where in the world can i get those banjo bolts from? the ones i got from summit were too long.
1 Fly SI wrote: http://www.markwilliams.com/br...D=194
Go to the bottom.
Also, Russell sells them
- tucking your brake lines
RotiEatter wrote: I want to relocate the brake lines, but I'm scared of messing with them... haha.
Anyone have good pictures of how they relocated their brake lines and what kinds of lines they used? Thanks.
EF8kid wrote: Go look at the page before this for pics of mine. They sell all differents lengths of line @ your auto parts store and theyre like 5 bucks a peice. 3/16th size line for japanese/metric/import etc...I bent them with my hands!
kidkombo wrote: dood the hardlines will kink when you re route them....they are already bent in intricate ways, there is no way in hell you can do a clean tuck behind the firewall...so yes i think its a stupid question as well lol all you need is a tubing bender, tube nuts and sleeves and a ton of reverse flare -3 fittings to -3male...and you will be set for life!
stillrockin18s wrote: Where can I pick up some metal brake lines and fittings online so I can tuck my portioning valve and brake lines. I prefer just straight pieces, my boy has a good bender and flaring tool.
Also can the portioning valve be mounted on its side? I am thinking of tucking them under the wiper cowl.
hondaZvic wrote: the metal lines and fittings can be picked up at your local autozone or whatever autoparts store you have, the lines come in rolls, and you can buy it by the foot or however much you need. at least here anyway.
painting, applying filler, welding
- shaving/painting your engine bay
JDMorgan wrote: usc icing is an example of a filler you can use. all polyester fillers are pretty much the same, it comes down to what they sell at your local auto parts store. i use evercoat products.
fventura03 wrote: do you (or anyone else) recommend using this on the shock towers and to cover small bolt holes in the engine bay? i'm trying to make my engine bay as clean as possible, but i dont want it to start cracking in a couple of years...
nerdsports wrote: you need to weld the holes shut first. then grind the weld down.
the icing is just a thin layer over the metal surface to cover the imperfections and leave a smooth flowing finish.
EF8kid wrote: bondo sucks, i used Evercoat Metal Glaze.
I_HATE_JDM wrote: evercoat rage extreme filler is your friend.
JDMorgan wrote: i never use normal fillers anymore. if i absolutely have to use a bunch of filler i use evercoat duraglass, but i like the polyester filler by evercoat. its expensive but it works awsome. it's very thin so you can feather it out quickly. i hate bondo brand products.... wont use them. evercoat has a sweet line of products so they have pretty much something for everyone.
JDMFantasy2k wrote: Any of you guys that have painted your bays, have you heard/seen/used this stuff??
https://www.paintscratch.com/
Apparently they sell OE paint in aerosol cans. Appears to have amazing feedback about the products and it's like 25/can.
Seems like a neat alternative for those guys who don't wanna krylon it and don't have a hvlp gun. I'm pretty interested in it i must say.
DarkBB4 wrote: usc icing
I think that is what (Bryan)Pandahatch used.......Ive heard good things about it too.
http://www.evercoat.com/productDetail.aspx?pID=1
[img]http://www.evercoat.com/imgs/products/MetalGlaze.jpg[/img]
-NA-aLL-thE-wAy- wrote: The Paint/Body special issue of Hot Rod Magazine said as long as it's 1/4 of an inch or less, and the chemicals are mixed correctly, you won't have an issue with cracking. Naturally you want it much thinner than 1/4".
Pandahatch wrote: I do a LOT of metal work, grinding, smoothing, etc...you don't necessarily have to seam weld. If I have a seam I grind it down almost flush to the panel under it and apply a couple spot welds to minimize distortion and warpage and grind those down, I apply filllr and end up taking off over half of what I apply. It's a long tedious project as well.
ezza wrote: I was told that when removing the seam sealant stuff you have to weld the seems for strength what exactly does seam welding do, and when you say a couple of spot welds, like 1 per 3 inches?
EF8kid wrote: I did ALL sanding by hand on my Cr-x's bay and the EK bay, cept on the core support like Brian...
oh evercoat metal glaze is kewl.
JDMorgan wrote: hand sanding with a block is about the best finish you will get, 2nd to an inline sander. rotating sanders tend to make shit wavy if you arent careful. most of the bay you cant even use an inline sander on tho so you have to pick between smaller blocks or rotating sanders.
evercoat and usc both have great products, just be sure to use the right product for your application and use it properly.
DarkBB4 wrote: wats a good THICK primer to spray to help fill scratches, i.e. make it easier to see flaws. etc.?
4d_ek9 wrote: I dont know if you can get in the US but in the uk i tend to use a brand called U POL and its called reface it awesome stuff you can whallop it on as thick as you wish and it will sag into the imperfections, you can get away with covering 40ish grit marks with it, and when its dry just guide coat and wet flat it with 500 / 800 depending on how thick u applied it.
Slappy wrote: My painter used a greenish filler primer(U-POL) that is thicker than your average primer. Once that first coat was layed on, any imperfections were more visible and could be touched up. Then a second coat was applied.
[img]http://autobodystore.net/Merchant2/grap ... polkit.jpg[/img]
-NA-aLL-thE-wAy- wrote: So is it best to use the metal glaze directly on the metal, then sand, then primer, or prime the bare metal, then glaze, then primer again? I know the metal glaze is designed to be used directly on bare metal, but I wasn't sure if one way was better than another. You know, chemical vs. mechanical bond and whatnot.
I_HATE_JDM wrote: I use evercoat rage extreme and it works very well.
- seam sealer/stitch welding/welding
PatrickGSR94 wrote: So what are you doing if you remove the seam sealer? I'm sure it has a reason for being there, are you sure it's a good idea to remove it?
JDMFantasy2k wrote:hey how are you guys getting rid of that seam sealer shit that is everywhere?
-NA-aLL-thE-wAy- wrote: Most people weld that seam; one for rigidity, two for aesthetics.
h22apwrdcivic wrote: sand blast
hondaboy4life wrote: or heat it up with a propane torch then wire wheel in places where you can reach.
-NA-aLL-thE-wAy- wrote: A torch and a wire wheel is actually faster/easier than sand blasting. I've done both. Sandblasting works, but it's time consuming, and time consuming means a lot of sand, and a lot of sand means more money. You can buy a wire wheel (for pneumatic tools, would be best) and a propane torch for under $20. The sheet metal is so thin on our cars I'm reluctant to sand blast in the same area for an extended period of time (like for the thicker seam sealer). Get a little heat in the sealer then hit it with a wire wheel, it'll come right out.
EF8kid wrote: I scraped every inch of seam sealer in my entire car mostly with this tool. Small prybar(also works great for separating spot welds):
[img]http://i161.photobucket.com/albums/t230 ... crx008.jpg[/img]
Some places i used a wire wheel too
JKGONZALEZ3 wrote: well i should ask i just took some seam sealer off and did some welding on the strut tower but i was wondering if you grind your weld down wont it weaken it or should it still be stronger than oem seam sealer was?
donut. wrote: welding makes the metal weaker in certain areas exept the particular area you weld. make sure you have the right setting
Boosted Rex wrote: The stuff your looking for is called self-leveling seam sealer. You use this stuff exactly like regular seam sealer BUT the key thing is that it is sandable because it is catalized. It costs about 30 bucks and comes in 2 tubes.
I can't remember the brand I used, but it was very similar to this
http://www.azautobodysupply.com/123fufamacas.html
Hayce wrote: You or anyone else mind elaborating on this?
Im up to here in my build now and Im unsure how to tackle it. Like is welding the seams the only options can you take it back flat and smooth it or? any ideas are good
EF8kid wrote: The tack's is stitch welding, He did multiple tacks on the one seam as u can see so he could make it all metal work and minimal filler.
[img]http://img.photobucket.com/albums/v739/ ... dimage.jpg[/img]
-NA-aLL-thE-wAy- wrote: The seam sealer is there to prevent water and moisture from getting in there and causing rust. If you stitch weld the seams (1-3" apart), around the strut towers for example, it adds strength to the chassis, as all the panels are tied together. Some choose to weld the entire seam continuously and then grind it down, but Panda is saying that isn't necessary.
hondaboy4life wrote: with sheet metal u just have to do a series of tack welds. Do one at one side, then another furthest away from the one u just did, then go back and do one 1 inch from the 1st one, etc etc. JUst dont let it get too hot.
sic944t wrote: i dont know if this will work its a trick my dad talked about from torch welding but you could get a wet wool sock and put it on the back side as a heat sink to prevent some of the warping
civicandy wrote: But from what i'm told, it's because it's in the middle of a large area, with no support to keep it from warping. Unlike when you do an antenna, which has curved metal around it to keep it from warping.
turbob18si wrote: water promotes rust, use a piece of copper on the backside of where your welding. Copper is a excellent heat sink and will pull the heat away from where your welding. There is a copper tool for this with a handle. check http://www.eastwoodco.com, they have alot of things that help out on our projects
wiring/electrical
- main engine harness tuck
drevinder wrote: engine baY'S LOOK good..but one question where do u guy's put the driver side harness ...and the passenger side ....make hole somewhere ? if so where..i'm stumped
ECKOTYPER wrote: what u wanna do is connect the passanger and driver side on the interior side of the firewall, and get all ur connections to come out of a central hole ... i cut a hole about as big as the driver side hole, underneath the heater core, and ran my harness in through that, ( i retained my heater core) so the heatercore hoses kinda disguise the harness below
ECKOTYPER wrote:some people ahve been asking me how to do some tucks and stuff, so i made a simple diagram showing more or less hwo a stock engine is routed, and how a tucked one is routed (when i do it) im not getting into detail because if u read this thread instead of looking for pictures theres alot of helpful material in here... heres 1 visual... so please stop asking for help (j.k im glad to help)
[img]http://img.photobucket.com/albums/v627/ ... aasdfa.jpg[/img]
SkankyEJ7 wrote: the only thing that MAY (its been talked about but never really proven) affect your engines performance would be altering the length of the wires would be the injectors. so i left the injector wiring the stock length on my harness, but everything else its custom length. and my car runs fine.
Rywire wrote: What are we looking at?? This is a harness for a bseries obd1 car (ill make them for obd0/2 also)
Its basically like a EK harness witout the drivers side shocktower plug. One end is all the engine functions ready for a Bseries with chipped obd1 ecu (to turn off things like vtec oil pressure, eld, and o2 heater).
The other end has the ecu /jumper intergrated. It also has the fuse box power wire setup to be used under the dash as well as the drivers side 14pin connector and 2 pin connector ready to be plugged in under the dash out of sight...
Feeding it through the firewall can be done easily once the stock harness is removed and pulled inside.
This is my first attempt at a tuck harness, and im sure it will improve as I learn more tricks... The only change I can think to make on this is to cover the long loom areas with that shiny plastic covering over split wire loom.
Give me feedback on this please, thanks everyone! Oh, and these are not going to be cheap.
-Ryan
[img]http://i70.photobucket.com/albums/i85/d ... uck001.jpg[/img]
[img]http://i70.photobucket.com/albums/i85/d ... uck006.jpg[/img]
[img]http://i70.photobucket.com/albums/i85/d ... uck005.jpg[/img]
[img]http://i70.photobucket.com/albums/i85/d ... uck004.jpg[/img]
[img]http://i70.photobucket.com/albums/i85/d ... uck002.jpg[/img]
Civichatch2k wrote: What gauge of wire to you need if you are extending the harness?
JDMorgan wrote: no thicker than it is now, but some of the wires are shielded. why would you ever want to add more wires to a car? most of us are ripping out every wire possible and shortening ones that are required.
Civichatch2k wrote: Let me rephrase. I may have to extend the headlight harness and the horn. I was just wanting to match the gauge of wire if that has to occur. Other than that I am not doing anything other than tucking the wires.
JDMorgan wrote: i think most of the wiring is around 18awg. not 100% sure tho. i actually have a box of wire from crap i took out of my harness, when i need wire i look for the same color and size and its normally there.
- tucking your headlight harness
Civichatch2k wrote: on the Ek's how are you guys hiding the headlight harnesses.
I know you are running them through the fenders but because they run in the front of the car and then to two main plugs after you get the harness off, what are you doing to re-route them?
I have the harness on the passenger side which is connected to the fuse box and I have the driverside which runs to the fire wall.
JDMFantasy2k wrote: on mine, i routed the headlight harness through the drivers side only. All of the wires in the passenger side of the harness are for AC components aside from the wires for the horn and cooling fan. So i ran those wires through the interior, re-pinned them into the connectors on the drivers side, and then ran wires through the harness for them.
American.Graffiti wrote: Question:
After stripping my harness I see that some wires have interference (sp?) insulation, my question is how do you advoid cutting the wires to length for the tuck? (Hope my question is clear).
B18EG6 wrote: you are referring to RF shield for some of the signals (distributor, knock are two that come to mind quickly).
If you choose to cut these, the best option is to replace the whole length from pin to pin with an already shielded wire. Some have had success with cutting the whole wire, soldering the conductors together, and resoldering the RF braid over top of them... however this is not perfect.
NJcoupe wrote: Where did u purchase the stuff to re-loom your harness. and what sizes?
B18EG6 wrote: bought the smaller expandable sleeving from waytek wire, and the larger sleeving locally. The sleeving ranged from 3/16" - 1/2" when collapsed. I also got a few rolls of wire from waytek for some good price Towards the end of assembly, I didnt plan too well and thats why there is electrical tape
The connectors were bought from Allied, along with their crimpers. The two posts on the firewall are for the starter and alternator leads, both 4ga.'
.adam. wrote: can someone give me some advice on depinning the connectors on the engine harness....i am tryin to put the braided sleeving on and cant get the connectors off. i know to take out the white inner piece, but then i get stuck. anyone got some pics or advice.
Hayce wrote: Tiny screwdriver or use a de-pinner...
What sleeving are you using? Stuff I used had velco and wrapped around the loom.
.adam. wrote: i was planning on ordering this:
http://www.xoxide.com/techflex.html
blackb18c1eg wrote: try Snap On, I just ordered a universal de-pinning tool from them. I think it lists for like $45, sorry I dont have a pic or a link.
.adam. wrote: o yeah and for the injectors i have yellow, white, red, and brown.....can anyone verify which colors go with which cylinder?
teal_dx wrote: I'm guessing you have white instead of blue...
[img]http://www.6thgearadvertising.com/misc2 ... or_box.jpg[/img]
ignore the resistor box part. this is if you were looking at your motor from the front.
YEL - BLUE - RED - BRN
[img]http://www.6thgearadvertising.com/misc2 ... uck/72.jpg[/img]
Here's looking at the injectors from the opposite side.
BRN - RED - BLU - YEL
be sure to double check them with a meter
black88si wrote: I am having a hell of a time figuring out how to de-pin my injector plugs....
Anybody know if it is even possible?
.adam. wrote: to depin the injector plugs get some needle nose pliers and pull really really hard on the little white circle tab thing sticking out where the two wires come out.
eblucarbonem1 wrote: quick question tho, when doing the main harness are you guys just extending wires or are there certain resistances that need to be met? how hard is this exactly any quick tips? thanks
AnToNy wrote: Shortening or extending a wire does not change the resistance going through it.
so it will not make a difference
DC2 Mang wrote: but there will be a power drop of around .1 volts at the points where you connect and solder
that is why you avoid cutting the o2 sensor wires because their signal to the ecu is between .1 and .9 volts
eblucarbonem1 wrote: so if im running 770's and doing a tuck harness do i need to run the wires through a custom resistor box or what?
RedZone wrote: you can use a stock honda resitor box and the wires are already at the end of the harness on the driverside strut box..... its the dead plug with the yellow/black wires....4 wires go to the injectors. If you trace out the wires at the dead plug, one wire will go to each injector. there should also be a power wire at the dead plug that turns on with the key. If you tap into this power wire and connect it to the power wire ont he resistor box and connect the 4 wires from the injectors to the 4 wires on the resistor box you will be able to now use low impedance injectors.
this is all assuming you have a civic or integra with a d or b engine
- pins.
ejwan wrote: finally found the company that does our oem honda pins
its Tyco Amp here is the link to our pin that we need Tyco Amp Pin (Note: Under Instruction Sheets: click on the first link its a PDF file)
Not sure if its P/N 316836 which is the female pin size S. (size M is 316838). this is the 040 series there is also the 070.
I don't know the P/N for the male plug yet (if someone know it would be helpful)
.dave wrote: PM user tony1. I believe he has a bunch of the pins.
- distributor wiring.
not so JDM Dan wrote: you shouldnt have to shorten the distributor wires, i ran mine under the manifold and it came out perfect
[img]http://i3.tinypic.com/262nkud.jpg[/img]
hayce wrote: hmm done things a little different,
The wires that come out from the distributor (like your pic there) I have lengthened so the plug is under the manifold (mine orginally were shorter than yours, I aws your pics & believe me I tried )
The problem lies with the other end of the loom. I want to have the 5 plugs from the motor stopping under the heater hoses. Then the cabin side wires that connect to them peaking out a hole ive made there. So with that in mind the length of the wires wrapped up in the black plastic + braid is too long.
not so JDM Dan wrote: oh i see, hmm so you want to be able to disconnect the engine harness from the engine bay under the heater hoses?
hayce wrote: Yeah. This is actually my 2nd go as the first time I did it I just ran the wires through the hole and then put the plugs on which, when I pulled the motor left the loom stranded/trapped in the firewall so I had to chop it (hole is not big enough to pass all the plugs through it)
- tucking your hid kit.
Beau Gotti wrote: Question for people with HIDs: where is everyone hiding their sh*t
SkankyEJ7 wrote:
[img]http://i17.photobucket.com/albums/b79/t ... C00676.jpg[/img]
and dont worry im pretty sure most all HID stuf is water RESISTANT! Noticce i did not say water proof, so im not liable if you try to submegre you hid's and cut them on
H8 O ATE wrote: thats where mine are, no problems so far, but i am using rubber stand offs, rubber washers, 2 reg bolts, 2 nylon bolts, and lock washers all around , might say its over kill, but i dont want my dis-continued HID's falling off on the freeway somewhere
as far as mounting, the Catz hid's have 4 bolt hole mounts on each corner, so all i did was drill & tap mounting holes on the frame rails
SHG_EasyE wrote: i ran my auxillary fan and hid wiring through the main harness to the fuse box and dash (for the fan switch)
[img]http://i29.photobucket.com/albums/c294/ ... 020798.jpg[/img]
[img]http://i29.photobucket.com/albums/c294/ ... 020691.jpg[/img]
- special wire loom [sleeving]
KILLA_EK9 wrote: Where do u get this special wire loom thingy??? Anybody..
teamsoy1320 wrote: it is for computer wire...go to http://www.xoxide.com or http://www.newegg.com and you can get it there
wEaK Squad *ATL* wrote: 1/8", 1/4", 1/2", 3/4", and 1" are the loom sizes I’ve used
BolivianFuego wrote: Im a little late here, but to all good little boys who ask... Just call Clause...
http://www.parts-express.com/wizards/se ... N=53646450
eblucarbonem1 wrote: how much and what sizes of this stuff are you guys using to do main harnesses?
http://cableorganizer.com/f6-wrap-around/
American.Graffiti wrote: I went to SVC http://www.svc.com [thanks EF8Kid aka Cha$e aka ballaholic] and just used the black sleeving kit. I have a good amount left over, I just might do a once over on mine so I dont have it as a waste.
- wiring/soldering basics
civicandy wrote: Since most of you guys are so good at wiring, I figured I would ask for tips. My current method is to use flux core solder and a soldering pen. I find that 2 hands is not really enough, since there are 2 wires, the solder and the soldering pen. Tips?
h22apwrdcivic wrote: get a clothes hanger and solder two aligator clips at two different points then use that to hold the wire tight while you solder. its what i use.
B18EG6 wrote: I just strip ~.25 - .5" of insulation from the wire, line the two wires up side by side, and twist them lengthwise around each other.
The end result is a soldered section no larger than the insulated wire, with no pointy pieces that could poke through the heat shrink
I doubt a picture is needed, but if you want one lemme know.
Also - hemostats work very well when holding wires while soldering
PatrickGSR94 wrote: I like to strip about 1" or a little more off each wire, make each wire into a hook shape, hook the wire ends together, then twist the ends and solder. That will make the absolute strongest solder joint, but you do end up with a slightly larger diameter than the original wire. If you have lots of wires with solders all next to each other then I guess that could be a problem.
wEaK Squad *ATL* wrote: ^ correct ^
but dont twist them too tightly because you want the solder to be able to penetrate each thread... solder does NOT sit on top in a bubble... when correctly done, it almost soaks into the wire and itll be very hard to pull apart again
PatrickGSR94 wrote: yep, and to do that, you need to heat up the wire so that the wire itself melts the solder. Don't melt the solder against the iron and let it drip onto the wires.
gabebauman wrote: PS: Don't forget to slide the heat shrink tube over one of the wires and set it back out of the way while soldering.
h22apwrdcivic wrote: Oh yeah and you heat the wire and not the solder that way the heat sucks in the solder making a permanent connection.
- ground wire on your valve cover
B18C Turbo wrote: One thing I have noticed about all these sick bays are no one is using the ground for the valve cover? What are you guys doing, not using one at all or is it invisible?
Anyone got pics of where every ground should be? I know of the battery -, valve cover, and tranny.
EF8kid wrote: Put it on the back VC bolt
- fuse box tuck
B18EG6 wrote: Would it be possible to extend the wires, and mount the underhood fusebox in the trunk? I thought about doing this... use 18ga wire to extend the smmaller wires, some 10ga and 8ga for the bigger ones.
Also I have about 20 ft of 0ga for the battery wires, and 4ga to run from the alternator to the fusebox
JDMorgan wrote: its VERY possible but thats like maybe ten 12 gauge wires, and an 8 gauge... thats alot of wire. not to mention the smaller gauge wires. the wire to the battery itself could be super short tho if you ran a wire right from the battery to the fuse block.
95jdmej1 wrote: as for a custom batt. tray do you mean just weld a smaller tray there ??????
What is the hard part about heater box and fuse box ? can i do it myself???
JDMorgan wrote: section the stock tray so that the bottem is the same size as your battery. if you relocated the fuse box under the dash i bet you could fit the whole battery in the space between the fwall and strut tower(instead of sticking out like oe battery does).
with the dash out the heater core, ac evap, and blower motor only have a few nuts and bolts holding them in. you could yank all of it out pretty quick, then just make a panel to weld or rivet in where the heater hose came thru the fwall. i am pretty sure on eg civics you can even put a din block off where the hvac controls were. i am not a fan of removing heat in general, but if you think it's worth it... go for it. there are actually a couple options if you did want to daily drive this car with no oem hvac shit... you can either run a universal heater box so you still have heat and defrost, these are electric so there is no hole in the fwall. the other option is heated windshield.
the fuse box relocation is pretty basic but takes a little work, mostly just unwrapping and rewrapping wires. if you are pretty good with wiring give it a shot.
DarkBB4 wrote: just a ?, when relocating fuse box.. how do u get the oem honda plugs through teh firewall?
Madness wrote: Uhmm.... Definately not. Disconnect them from the box, and push them throught the firewall one at a time.
h22apwrdcivic wrote: yeah they all disconnect from the fuse box, there are about 5-6 plugs on the back of the fuse box, disconnect and pull them back through the firewall and then reconnect. that was the easiest part. if you figured that part is confusing you might want to cease all further projects.
[img]http://img480.imageshack.us/img480/5096/1011325al9.jpg[/img]
Thats a test fit before I put the dash back in the car. Dont mind the cover, its fu_ked and I have a brand new one anyway.
JDMFantasy2k wrote: how bout this for a fusebox relocation :P
[img]http://img.photobucket.com/albums/v217/ ... s/0006.jpg[/img]
[img]http://img.photobucket.com/albums/v217/ ... s/0008.jpg[/img]
yeah that took a lot of creativity. Works good though, plus the glove box is still useable
NHswaps13203 wrote: run no heat haha, wait dont do that thats why i sold that car.
[img]http://img108.imageshack.us/img108/961/h2b25uf9.jpg[/img]
- low brake fluid switch
B18C Turbo wrote: Just wondering what to do about holes that im drilling to run wires thru. I need to cover the holes with a water tight seal, for example I drilled a hole in the vents in front of the windshield for the wiper wires to go under the dash rather thru the brake booster.
SO now i need to seal that hole up, and seal up the hole where the wires originally came thru to the engine bay, help.
JDMorgan wrote: brake fluid switch: remove the ground from the ground block and the signal pin from the connector right behind the firewall. then you can just take the switch off the cap and it looks way cleaner. if you dont notice your brake fluid low on your own maybe cars aren't your thing. ahaha.
wiper wiring: is a bitch. the best way to do it is cut a rectangle around the grommet hole already there, then another rectangle the same size on the firewall between the cabin and the cowl area so it isnt visible from the bay. then just but weld the pieces of metal in the opposite hole. then just run the wiring all inside your cabin right to the cowl and ur done.
air conditioning, power steering and heating
- reservoir tank/power steering deleting/tucking
maxpsi wrote: Ehh. PS fluid will pressurize out of a filter as well as it will pressurize out of a PS reservoir, so either way it will leak all over your engine bay. lol There will be some fluid that will stay in the rack regardless (which IMO is enough). You can hide a reservoir easily near the crossmember and shorten the lines. It all preference. Just make sure there is some fluid in the rack AND that it isn't open to the environment.
-NA-aLL-thE-wAy- wrote: If your car came with power steering and want to eliminate the parasitic drag on your motor, and the extra weight, you can remove the pump/belt/hoses. If you retain your p/s rack, it's in your best interest to "loop" it, which usually consists of a kit that is sold (usually home made) or you can make it yourself. This keeps fluid in the rack and and keeps it lubricated so that it doesn't wear out. Replacing your p/s rack with a manual rack is also an option. It will be more difficult to steer the car at a stand still, but nothing major.
-NA-aLL-thE-wAy- wrote: I ran across this:
"Buddy Club Power Steering Fluid dramatically improves the power steering fluid boiling point during sports driving. It contains a special sealer to prevent leaks from oil hoses and joints. Unlike brake fluid that uses hydraulic pressure fluid, power steering is controlled by an oil pump, which only has a pressure of 60kg/cm2. Therefore, it is likely for the ordinary power steering fluid to reach its boiling point during sports driving and for cars that are equipped with turbo, which causes more heat in the engine bay. Power steering can seize when the fluid reaches the boiling point.
The ultimate additive for power steering fluid (In red).
Improves the steering response using a silicone based additive (In blue). "
Hayce wrote: Swap in a manual rack or loop the lines.
To loop the lines remove all the resiviour/pump gear and loop the two lines that the pump/resiviour ran to. Theres a thread in the ITR forum somewhere. One word of note for RHD people such as myself, all the pics on here show the lines to loop as being at the front of "kunckle" on our cars its flipped over so the lines to loop are at the back (real PITA on an ek...).
Drop nearly all of the fluid and some people add a breather in line.
http://www.honda-tech.com/zerothread?id=184202
SHG_EasyE wrote: you definatly do need a loop dude, and a breather. those 2 lines are not connected internally, so if you were to block them off, it would be extemely hard to turn the wheel, it would get harder the farther you turn it; building up pressure. if it were pointless why would the realtime team be using it?
i personally run a looped setup with a resivior and breather. for a while it was just a pinhole in the resivior cap and it wasnt big enough, when turned full lock you could hear the pressure releiveing slowly through the cap, and the steering would get hard if i turned the wheel quickly. i made the hole bigger and it was fine.
this is my new setup with a breather filter
[img]http://i159.photobucket.com/albums/t131 ... 030406.jpg[/img]
PatrickGSR94 wrote: A non-PS rack will have a slower ratio in order to help lower steering effort somewhat, but you'll end up with like 3.5 turns or more, lock to lock, instead of about 3 turns with a power rack. I think most people who ditch PS want to retain the faster ratio rack, which is going to be more responsive than a slower ratio rack. That's why they opt to do a vented setup on a power rack.
SHG_EasyE wrote: as far as the p/s vs non p/s rack i actaully had the manual rack which came in the car, but opted to do the p/s with breather because of the quicker ratio. even the manual rack with a quaife quick ratio rack and pinion is a half turn longer lock to lock than a stock p/s rack.
IMO the manual rack just feels very sloppy and theres no road feel compared to a looped p/s rack. maybe a dc manual rack is different than the civic? idk but i went from the OEM CX manual rack to a GSR power rack and felt a HUGE difference in feel. the GSR rack that came out of my old gsr has been looped for 3 years and no sighns of wear... you just have to make sure there is plenty of Honda p/s fluid in it... they tend to get a little sticky if you use anything else
93allmotorcoupe wrote: You can also T the two lines and add a reservoir.
Jared Im finally going to help you out, lol. There should be 2 fittings you need to loop. One is 14mm X 1.5 and the other is 16mm X 1.5. I used these adapters (I ordered from this site too and they came in a few days): http://bakerprecision.com/adapt20.htm
Youll need part numbers FCM2240 and FCM2241. From there I used whats called socketless hose. Part number FCM1512 on this page ( http://bakerprecision.com/aqp1.htm ) fits on the adapters listed above. Part # FBN0600 is the hose I used to loop them, I bought 2 ft but you could probably get away with 1 ft. I didnt use a breather and I havent had any problems. I did drain a lot of the fluid out of the rack though, only leave a little in there to keep it lubricated. If you wanna use full SS braided off the adapter fittings you can do that and piece together your own lines. The hose im using has been working great though and its black so it stays out of sight. Oh and if you have a third hole in your rack like i did that needs to be plugged it should be a 14mm X 1.00, which is the same size as a flywheel bolt, which is what i used to plug it. I can post pics of my setup if you want to see it, let me know.
Edit:: Threw up a pic so you can see what my setup looks like:
[img]http://i62.photobucket.com/albums/h96/9 ... G_2501.jpg[/img]
- a/c removal
h22apwrdcivic wrote: i removed my a/c evaporator complete box assembly from behind the dash, and purchased a non a/c box from hondapartsdeals.com it doesnt free up a great mass of space but i wanted to retain my heat, b/c i do get cold very easy even in fall. but there is a good 5x3" space for something above there, i believe i will stash my ignition coil and the msd ignition main box on top of it with rivets.
B18C Turbo wrote: Ok I need that piece, i want it! What is it called actually? Im talking about the ac removal part
JDMorgan wrote: heater duct... part 79810-SR3-A01 for a 94-01 teg.
JDMorgan wrote: just look in the air conditioning section of whatever honda parts site you buy thru, then grap the piece that goes where the condenser goes and the plug too. make sure you select the base model of whatever car you have.... so civic cx, or integra rs.
JDMorgan wrote: http://www.acuraoemparts.com/delray/jsp ... vinsrch=no
^part #7: 79810-SR3-A01 DUCT, HEATER
^part #18: 91631-SR3-000 PLUG, AIR CONDITIONER HOLE
- ”heater” removal
.adam. wrote: what are you guys using to plug up the heater hose outlet and inlet when you take out your heater core.....i dont want to loop a hose.
donut. wrote: you can get a rubber plug from pepboys for both of them. or for the one on the side of the head, you can take out the spout with a (21mm?) socket and plug it. i plugged mine with the bronzish plug thing near the dizzy. it takes an alen wrench
CRXBart wrote: Oh you guys meant on the engine? Mine is looped for now. I am removing the water pipes, and welding the ports shut soon though.
miscellaneous engine bay component
- getting rid of the carbon canister
jdmb16acivic wrote: When you do get rid of the carbon canister put a hose on the breather vent line from the gas tank and run it down to the bottom of your engine bay so when you're driving the air underneath the car will suck away the vapors. Or you can just smell the gas all the time. Just know you will smell some gas fumes from time to time when you take it off.
JDM Dan wrote: i just cut the hard line at the back of the car and ran a rubber hose out just past the bushing on the trailing arm, no smell of gas in the car.
[img]http://i5.tinypic.com/262b0wo.jpg[/img]
[img]http://i2.tinypic.com/262b1pc.jpg[/img]
droppedcrxsi wrote: charcoal canister will never make a cel turn on.
the evap purge solinoid will throw a code on obd2 cars, if you go obd1 you can just take it off without a problem
DFW wrote: I just took out the huge canister, what do i do about the line on the left and the little canister that it goes into? it's kinda right under the battery.
JDMFantasy2k wrote: the pinkish line is just a breather so you can trash that. Hold onto the canister for when you need to pass smog, otherwise just block off the hose that runs back to the fuel tank so you can hook everything up again. Least that's what i did.
DFW wrote: Like this? Have a hose from
there:
[img]http://img512.imageshack.us/img512/9245 ... 450dr6.jpg[/img]
to here? this is on the firewall haha shitty picture
[img]http://img512.imageshack.us/img512/162/ ... 451wj6.jpg[/img]
gabebauman wrote: That's how we did it on my buddy's coupe.
Connect the hose to the plastic drain tube that dumps out below the car.
JDMFantasy2k wrote: or you guys can stop letting FLAMMABLE fuel vapors from leaking out of your car all the time by plugging the line and letting the fuel tank pressure bypass work naturally when the tank reaches it's maximum safe pressure like honda designed it.
think, ever leave a 5gallon jug of gas in the sun? Fucker expands real quick, gas in your tank does the same thing.
So if you don't drive your car, evap isn't running, fumes are expanding, eventually they need to be purged or else your car turns into a potential bomb. I promise if you block off your tube (or even just disconnect your purge solenoid), you'll hear a funny noise from your car on a warm day.
civicandy wrote: Where is the pressure bypass located? Currently I just ran a hose from the vent down below the crossmember
JDMFantasy2k wrote: ok, there's 3 pipes that come from the gas tank, fuel, fuel return, and fuel vapor. The fuel vapor hose on an EK comes almost all the way to the charcoal canister, and then a rubber hose connects it to the canister. What i did was take out the canister, and i cut the vapor hose back near the crossmember where its out of site. Then i clamped a rubber hose to it, and clamped the end shut. So if you need your canister back, install a different rubber hose to the canister and you're done. So i'm assuming that's what you're trying to say you did.
Not sure what you mean by "by pass". Are you referring to the open atmosphere fuel pressure relief valve? I believe it's on the top of the gas tank. Mine makes a weird buzz/humm when it's open. Hope that cleared it all up
- radiator overflow bottles
itekdu wrote: how is everyone doing their rad. overflow bottles? im sure I saw somewhere someone had done a stainless one?
gabebauman wrote: Mine is mounted between the bumper and the radiator. I just purchased a couple feet of new hose to run over/around/behind the radiator. You can't even see it.
not so JDM Dan wrote: i made a small bracket with some strip aluminum and bolted it to the core support and to the oem bracket...
[img]http://i14.tinypic.com/2hwirmu.jpg[/img]
- type of battery you can use
SPOON_BeIgHtEeNsEe wrote: where are u guys putting ur battery? i was thinking either the rear trunk or get one of them smaller batteries and putting it in the glove box.... for those who has the battery in the glove box which one are u running? and how are u guys going about securing it down?
Pandahatch wrote: In my hatch the battery is in the glove box, it's a lawn mower battery from Meijer, 270CC amps. NEVER had a problem with it.
-NA-aLL-thE-wAy- wrote: On my CRX I used a moto dry cell battery behind the driver seat. It will be under the dash in my current project. I haven't decided on a brand yet. I was looking at odyssey, but I've heard bad things about those...
PURO~SURCAL wrote: where do you get those battery terminal from on the firewall i need some bad
h22apwrdcivic wrote: not my car but i got mine at
summitracing.com they are 14.95, part number is sum-g1430
- how to hide your brake booster vacuum line
phresh_5 wrote: FIY, since I havn't heard anyone talk about it yet...
Easy way to hide the brake booster vacuum line:
Put the intake manifold vacuum nipple in a vise and twist it so it points downwards. I did this to my Skunk2 manifold and it turned easily. The fitting is only pressed into the manifold. I'm sure stock manifolds can also be done like this.
Also, flip the brake booster 180 degree's. This will put the booster nipple on the bottom left corner instead of the top right.
- throttle cable
xtremeness101 wrote: I need some advice from you guys, what are my options for a way to re-route my throttle cable? And also, are you able to unplug the fuse box and just move it into the cabin of the car?
cubish wrote: get rid of the gsr throttle cable.. use a type r cable...it will bolt to the jg manifold and be easier to hide
JDMorgan wrote: you need an itr spring and throttle wheel, then of course cable and bracket. im workin on a bracket that replaces the aicv.
- hidden hood latch cable
teal_dx wrote: if anyone doesn't, here's a link to a how-to:
http://civic-eg.com/viewtopic.php?t=112
- running no torque mounts
PatrickGSR94 wrote: And what's this about not running torque mounts?? You mean some of you guys are driving your cars around with only the 2 side engine/tranny mounts holding the engine in place?? How is that possible? How does that engine not rock back and forth all over the place and cause nasty sounds and possibly break parts?
ATS*Mark wrote: im not running torque mounts... 85a innovatives
- k series alternator solution
Boosted Chemist wrote: Found this in another thread, nice way to clean up some k series uglyness?
http://www.etdracing.com
- bolts and washers
Fuster_Cluck wrote: Can someone give me some info on the fender/headlight hardware on this EG? Thanks!!
[img]http://img.photobucket.com/albums/v495/ ... baybay.png[/img]
-NA-aLL-thE-wAy- wrote: Maybe Mugen? $25 per set.
[img]http://www.kingmotorsports.com/images/P ... ge/391.jpg[/img]
B16B_coupe wrote: look threw here. http://www.fastener-express.com/index.a ... tegory=218
jarel wrote: just basic countersunk washers and allen heads. search online for them or hit up a GOOD hardware/bolt store near you. But yikes!...$60 for all the bolts under the hood? Glad i didn't spend that much for all of my mine, probably less then half of that.
stealthmode62 wrote: The 10mm bolts are M6x1.00 I bought a bunch last week and have been installing them.
ek4kid wrote: anyone every try this site for bolts/countersunk washers? http://www.tastynuts.com/
just stumbled on it
HOTSAUCE01 wrote: What up... found these bolts for ya..
http://passwordjdm.com/PasswordJDM-Fend ... 997C0.aspx
little pricey, but sick!!
tools
- flare tool
itekdu wrote: Can someone tell me the brand of flare tool you guys are using? I'm trying to find one, but con only seem to find 45 degree flare tools, not 37...
-NA-aLL-thE-wAy- wrote: Try www.summitracing.com or www.anplumbing.com . You can probably find a 37* flare tool on eBay too, used and cheaper.
[img]http://www.anplumbing.com/shop/images/parker.jpg[/img]
$174.99 anplumbing.com
http://www.anplumbing.com/shop/index.ph ... dept=Tools
[img]http://static.summitracing.com/global/i ... 900311.jpg[/img]
$29.95 summitracing.com
http://www.summitracing.com/parts/SUM-900311/
I didn't see much on eBay, but that Summit one is fairly cheap anyway. Plus they'll probably send you a super cool Summit hat if you order from them.
Here's a baller set...
[img]http://www.eastwood.com/media/catalog/p ... p16264.jpg[/img]
$399.99 It does 37* and 45*, including stainless.
http://www.eastwood.com/flare-pro-4-in- ... -tool.html
im bored at work.
integrax97 wrote: Ok, so i got another line done tonight haha... I ran out of line so im gonna have to wait till this weekend to finish off lines for the bulkheads. Im excited cuz i really didnt know what i was gonna do cuz the lines i was flaring before with the crappiest peices of shit ever flare tool from jegs and summit wasnt working with the summit line i bought. So i did a little research and finally got me some GOOD tools. I had to pay a little more but it works. Also instead of using the shitty summit SS hard lines, i went on mcmasters website. They have tubing that is SOOOOOOOOOOOOOOOOOOOOOO much better than what summit offers. im happy i found this website.
- soldering iron
Boosted Chemist wrote: the weller one that looks like a gun, they heat up instantly and solder a lot better than the pens imo.
[img]http://cableorganizer.com/images/solder ... ller-s.jpg[/img]
NHswaps13203 wrote: Snap On cordless FTW
ive had mine for three years
little pricy but i buy the best so dont ask to borrow lol
[img]http://img145.imageshack.us/img145/2110/snapfg9.jpg[/img]
H8 O ATE wrote: damn balla !
I thought this was cool, weller makes one that looks almost identical to the snap on...
[img]http://www.action-electronics.com/grc/wepsi100k.jpg[/img]
on another note
I love my weller...wifey bought it for me and its going strong...
[img]http://www.cooperhandtools.com/_cache/6 ... b3f2c2.jpg[/img]
and although im sure th snap on is dope, for cordless duties, you cant beat the weller pyropen Jr...so f'n small
[img]http://www.cooperhandtools.com/_cache/d ... b2eabd.jpg[/img]
- micrometers
NJcoupe wrote: The fluke 87 is the best thing I could have ever purchased/used in terms of multi-meters.
H8 O ATE wrote: 88 es bueno!
[img]http://us.fluke.com/images/products/ind ... 7_200p.jpg[/img]
the 87 should look about the same, this is the only pic they have on their site
[img]http://us.fluke.com/images/products/ind ... 3_200p.jpg[/img]
- mig welders
vega_ROCKS wrote: yeah I saw this one..
http://www.honda-tech.com/showthread.php?t=1858554
[img]http://img406.imageshack.us/img406/8839/weld1ma2.jpg[/img]
Decent for a beginner??
DC2 Mang wrote: I have the lincoln HD100 pak welder that im using for my shave, it cost's around $400 but only runs off 115 amps and plugs right into any wall outlet. Also it has the power to weld 1/4" mild steel, uses flux shielded wire and can be converted to a gas shielded welder for around $100
well worth the extra money if you plan to do more than an engine bay shave down the road
- misc
Slappy wrote: You can order a HELMS manual they can ship it straight to you. 1-800-782-4356
reserved for more info.
spnfedeg6
65% ricer
Re: customized engine bays. pics. theory. discussion.
Post by spnfedeg6 » March 29, 2010
Well I guess I will jump in and post some progress pics of my bay. There is about 200-250 hours of metal work and body work thus far. I have been working on the bay since November. And doing some other shit too. I had all suspension parts powdercoated. More updates to come as I progress. Image Image Image Image Image Image Image Image Image Image Image
Post by .saint » March 29, 2010
damn, looks fantastic!
i wish i had a garage, makes me so jealous seeing all these cars parked in garages. hahaha.
cant wait for his bay to be done. great work on the seams! :thumbup:
Post by 77 » March 30, 2010
Awesome. Stuff.
Will read later, just looked at the pics for now.
spnfedeg6
65% ricer
Post by spnfedeg6 » March 30, 2010
.saint wrote:damn, looks fantastic!
Thanks guys, I cant wait for it to be done too!! Im shooting for it to be completely done by Import Alliance. Carlisle is a long shot, lol!
Post by .saint » March 31, 2010
haha yeah.
i never been to IA. been considering it though this year.
Jams_ek
Post by Jams_ek » March 31, 2010
nice homie lookin good..
