Lexan window questions.
Post by 77 » April 24, 2006
Prok0 wrote:I dunno, it seems like if you made the filler in the lexan window you would have to make some supports for it as well, because the lexan will bend when you put pressure on it...
Especially if you were daily driving the car and were filling up regularly...
I would say just throw it in the rear and just run it from the stock filler tube position, cut that out and then run a new one to the fuel cell maybe..
Another option I'm entertaining is having a carbon panel to mount the filler to, and just having the lexan start after that. I had only accepted mounting directly to the lexan after seeing this done on the Norris Designs car.
