WTB Rear Disc Conversion.
https://thejdm.com/forum/viewtopic.php?f=81&t=8923
Author:  homere [ July 20, 2007 ]
Post subject:  WTB Rear Disc Conversion.
I have a 99 ex coupe and im looking for the 99-00 civic si rear disc setup. If you have one and would like some cash for it hit me up.
Author:  Zero [ July 20, 2007 ]
acttually you should be looking for any rear disk setup from a integra, del sol, or civic si... the only things you really need from a Si of that year are the E-brake cables and the propotioning valve... i know that cause i used DA trailing arms for my rear disk conversion on my 99 Ex
Author:  brandonryan [ July 20, 2007 ]
Zero wrote:. i know that cause i used DA trailing arms for my rear disk conversion on my 99 Ex
WOW, i have always wondered if DA trailing arms would bolt up.
Do the DA lower control arms bolt up on a civic?
Author:  Zero [ July 21, 2007 ]
when i got it it came with everything so i took off all mine and used those that were on it... so far i havent had any problems...
Author:  homere [ July 21, 2007 ]
oh i see. I knew the del sol discs fit, but i didnt know i needed the proportioning valve from the si. I work at Advance Auto so maybe i can snag one of those valves for cheap with my discount haha. I know of a kid that has had an integra just rotting away in his yard for like 5 years. I will stop there and try to snake the discs off of him. Thanks for the info.
Author:  munster [ July 21, 2007 ]
Even if you find a set that the trailing arms won't work you can pull everything off of and use it. Which is what I did.
Author:  homere [ July 26, 2007 ]
I found a set off an integra i can get for like 50 bucks. So i can't pass it up. Thanks for the info though.
Author:  hondalowlow [ October 04, 2007 ]
i got mine from a 00 si
