Honda FIT stats and options
https://thejdm.com/forum/viewtopic.php?f=69&t=5458
Page 1 of 3
Author:  JDMcd8 [ January 12, 2006 ]
Post subject:  Honda FIT stats and options
The Fit will arrive as an MY2007 automobile.
Model ID GD3747EW - Fit 5 Door Base - 5 Speed Manual Transmission
Colors - Nighthawk Black Pearl/Black, Vivid Blue Pearl/Black, Lunar Mist/Beige, Milano Red/Beige, Storm Silver Metallic/Black, Taffeta White/Beige
Model ID GD3767EW - Fit 5 Door Sport - 5 Speed Manual Transmission
Colors - Nighthawk Black Pearl/Black, Vivid Blue Pearl/Black, Blaze Orange Metallic/Black, Milano Red/Black, Storm Silver Metallic/Black, Taffeta White/Beige, Taffeta White/Black
Model ID GD3847EW - Fit 5 Door Base - 5 Speed Auto Transmission
Model ID GD3867EW - Fit 5 Door Sport - 5 Speed Auto Transmission
Exterior Color Samples based on JDM Honda website...
Nighthawk blk pearl Image
vivid blue pearl Image
Lunar mist- no sample but i presume it will be close to this pic Image
Milano Red Image
Storm Silver Metallic Image
Tafetta White Image
Blaze Orange Metallic- Exclusive to the Sport model Image
Some interior samples based on the JDM site Image Image
Blaze Orange Metallic/Black, Milano Red/Black and Taffeta White/Black are exclusive color combos to the Sport trim.
2007 Honda Fit- Specifications
By American Honda Motor Company
Sun, 8 Jan 2006, 17:06:00
Torrance, Calif. 01/08/2006 --
. Fit Fit Sport
Engineering
Engine Type In-Line 4-Cylinder In-Line 4-Cylinder
Engine Block/Cylinder Head Aluminum-Alloy Aluminum-Alloy
Displacement (cc) 1497 1497
Horsepower @ rpm (SAE net, Rev 8/04) 109 @ 5800 109 @ 5800
Torque (lb.-ft. @ rpm) 105 @ 4800 105 @ 4800
Redline (rpm) 6300 6300
Bore and Stroke (mm) 73.0 x 89.4 73.0 x 89.4
Compression Ratio 10.4:1 10.4:1
Valvetrain 16-Valve SOHC VTEC (R) 16-Valve SOHC VTEC (R)
Multi-Point Fuel Injection x x
Drive-by-Wire Throttle System (TM) x x
Front-Wheel Drive x x
CARB Emissions Rating LEV-2 LEV-2
Direct Ignition System with Immobilizer x x
100,000-Miles-or-More Tune-Up Interval* x x
Does not apply to fluid and filter changes. Exact mileage is determined by actual driving conditions. Please see your owner's manual for more details.
Transmissions
5-Speed Manual Transmission x x
Gear Ratios:
1st: 3.462 x x
2nd:1.870 x x
3rd: 1.321 x
x
4th: 0.970 x x
5th: 0.757 x x
Reverse: 3.231 x x
Final Drive: 4.294 x x
5-Speed Automatic Transmission (available) x x
Gear Ratios:
1st: 2.995
x x
2nd: 1.678
x x
3rd: 1.066
x x
4th: 0.756
x x
5th: 0.550
x x
Reverse: 1.956
x x
Final Drive: 4.562
x x
Body/Suspension/Chassis
Unit-Body Construction x x
MacPherson Strut Front Suspension x x
Torsion-Beam Rear Suspension x x
Stabilizer Bar (mm., front) 21.0 21.0
Electric Power-Assisted Rack-and-Pinion Steering (EPS) x x
Steering Wheel Turns, Lock-to-Lock 2.41 2.41
Steering Ratio 12.8 12.8
Turning Diameter, Curb-to-Curb (ft.) 35.6 35.6
Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.) 10.3/ 7.9 10.3/ 7.9
Wheels 14" with Full Covers 15" Alloy
All-Season Tires P175/ 65 R14 81S P195/ 55 R15 84H
Compact Spare Tire x x
Interior Measurements
Headroom (in., front/rear) 40.6 / 38.6 40.6 / 38.6
Legroom (in., front/rear) 41.9 / 33.7 41.9 / 33.7
Shoulder Room (in., front/rear) 52.8 / 50.6 52.8 / 50.6
Hiproom (in., front/rear) 51.2 / 51.0 51.2 / 51.0
Cargo Volume (cu. ft., seat up/down) 21.3 / TBD 21.3 / TBD
Passenger Volume (cu. ft.) 90.1 90.1
Seating Capacity 5 5
Exterior Measurements
Wheelbase (in.) 96.5 96.5
Length (in.) 157.4 157.4
Height (in.) 60 60
Width (in.) 66.2 66.2
Track (in., front/rear) 57.3 / 57.1 57.3 / 57.1
Curb Weight (lbs. MT/AT) 2432 / 2514 2471/ 2551
Weight Distribution (%, front/rear, MT) 61.8 / 38.2 61.6/ 38.4
Weight Distribution (%, front/rear, AT) 63.3 / 36.7 63.2/ 36.8
EPA Mileage Estimates*/ Capacities
5-Speed Manual (City/Highway) 33 / 38 33 / 38
5-Speed Automatic (City/Highway) 31 / 38 31 / 38
Crankcase (qt.) 4.4 4.4
Coolant System (gal.) 1.4 1.4
Fuel (gal.) 10.83 10.83
Required Fuel Regular Unleaded Regular Unleaded
* Based on 2007 EPA mileage estimates. Use for comparison purposes only. Actual mileage may vary
Author:  benjamin [ January 12, 2006 ]
yuck....
Its cool for what it is, but it is what it is.
i hear you it has a lot of possibilities as well, it may be the next CRX...who knows..
:roll: I hope not.
Four door wagons just dont do it for me, its to tall in comparison to the rest of the body... its really stubby.
benjamin wrote::roll: I hope not.
I agree, but their is something about the "modded" ones ive seen out of japna that sparks my interest.......
Author:  .saint [ January 12, 2006 ]
i like them alot.
i am going to preorder one in march.....once they can confirm the release date....so I may want to MOD this area....(hint.. hint)
JDMcd8 wrote:i am going to preorder one in march.....once they can confirm the release date....so I may want to MOD this area....(hint.. hint)
im way ahead of you.
Author:  Ek20A [ January 12, 2006 ]
Ugly :roll:
Author:  Sean @ NDF [ January 12, 2006 ]
I'm not sure about all this drive by wire thing for performance....when it comes down to it, there has to be a delay in response, no matter how minut it is....
but I am glad to see they are keeping the NBP color...
