96-8 to 99-00 rear defrost wiring???
https://thejdm.com/forum/viewtopic.php?f=61&t=8893
Author:  yesSIR-S [ July 13, 2007 ]
Post subject:  96-8 to 99-00 rear defrost wiring???
so i have 99-00 climate control now...how do i wire up the rear defrost button? p.s. i need a 99-00 dark gray dash please
Author:  brooksto [ July 28, 2007 ]
"to get the rear defroster working you need to tap a wire (baby blue with a yellow stripe) from the big plug that sits in front of the heater core and tap that into the baby blue with yellow stripe wire on the big green plug thats in front of the fuse box, the wire is at the end of the plug next to a green wire. once u do that you will see your relay click."
from http://www.honda-tech.com/zerothread?id=605432
