DIY Maplight Install into EK
step by step diy guides.
Airbag Club
Post by Airbag Club » February 25, 2004
Kinda old, but useful!
I was bored one day searching through hondaautomotiveparts.com, and I came across the maplight assembly out of a 2000 Civic SI. An idea immediately popped into my head, "That would be cool if I had maplights in my hatch!" So, for $28 for the whole assembly, I thought to myself, what can I lose, so here it is:
Items needed
- Maplight assembly, Part #34256-SR3-901ZB
- 16-18 gauge wire
- Wire connectors
- Razor Blade
- Cardboard
- Marker
- Screwdriver
- Patience Image
1. First remove the driverside sun visor, and driver side A-pillar panel.
2. Take the maplight assembly and make an outline of the shape of the base onto cardboard, this will serve as a template for cutting the hole.
3. Take the template made in step 2, and trace it onto the ceiling of where you want to install the maplights. Image
4. Next use the razor blade and carefully cut out the outline you drew on the ceiling of the car. Image
5. Next, feed two wires through the ceiling, from the driver side of the ceiling to the center of the ceiling where the hole is.
6. On the maplight, there are two grounds, which you have to use solder to connect. The positive requires one female connector to attach to.
7. Connect the ground wire to a solid ground, and tap the positive wire to the positive dome light wire, which runs along the A-pillar, and it a White/Red wire.
8. Finally, insert maplight assembly into the hole which you cutout. The maplight has prongs which keep it held in place. Image Image Image
Hope this helps, and IMO, it is really worth it. The lights are extremely bright, and they are very useful.
Post by .saint » February 25, 2004
yes! ill be doing this install into my ek as soon as i come across the money. i always loved this piece in the si. and you are right about the brightness. and + its better then trying to break your arm and reach back and grab the dome light.
nice how-to!
Airbag Club
thanks. this was old, since then i changed out to integra maplights!! they have two push buttons instead of a sliding switch. check out your local junk yard, i am sure you will be able to find one. i got mine for $10!!
do they look the same? same size and whatnot?
Airbag Club
yea they are the same size and everything, just that there are two push buttons in the middle instead of one sliding switch. so you can turn either side on separately.
ohh sweet. good deal ill be on the lookout. thanks for the how-to and the 'upgrade' muahaha :blang:
randy
Post by randy » March 07, 2004
wow ryans contributing to the forums more than me hahaha
5thgenh4tch
Post by 5thgenh4tch » August 12, 2004
great diy, i have been contemplating this on my egg..
Post by .saint » May 10, 2005
installed mine today :up:
Post by Sean @ NDF » May 10, 2005
Mine came with my car =) lets get some pics jon!
