*HOW TO: Old school... Glowing "Si" gauge logo tri
step by step diy guides.
JoshuaVTEC
Post by JoshuaVTEC » January 18, 2004
This was originally invented by my friend Jeff and spread all over the internet 8)
How to make the "Si" logo on your gauge cluster glow...
Here's what you'll need:
-Phillips head screwdriver
-Flathead screwdriver
-400 grit or higher sandpaper OR nail polish remover
-Your gauge cluster :lol:
It should be noted that the orange gauge needles are rather finicky and will break off easily if you man-handle them. A replacement from hparts.com is about 20 bucks...but if you're cautious you shouldn't even come close to breaking them.
Start by unscrewing the two screws on the underside of the top of your outer bezel...in my case it's an aftermarket one :beer: Image
Next take the four Phillips head screws out of all four corners of the gauge cluster assembly. The entire assembly will simply pull out once you're done. Image
On the back of the cluster will be four wiring harnesses you will have to un-clip. There's two large blue ones, a small green one, and a small yellow one. The whole cluster will separate from the dash now. Image
Now you can get your ass out of the cold and take it inside to work on it in the comfort of your home. Partake in some yummy Wawa coffee... Image
Time to take off the outer clear shell. On the bottom of the cluster is three clips, on the top of the cluster is four more. Use the flathead screwdriver if they give you trouble. Image Image
Next is the black outer bezel. Three clips on the bottom, four on the top. Image Image
Unscrew the light bulb/wire on the top of the cluster. It simply turns a quarter turn and pops right out. Image
Now pull off the gauge bezel overlay, in my case a carbon fiber CTR version :2: It is held on by the two small white nubs in the bottom two corners. Image
The cluster should look like this, and here is your victim: The fuel/temp gauge area :*) Image
On the back of the cluster, right behind the fuel/temp gauge, is two sets of three Phillips head screws. Remove them. Careful, the fuel/temp gauge will drop right out now. Image
You can set everthing else aside now, you should be left with just the fuel/temp gauge... Image
Flip the gauge over and find the area directly behind the "Si" logo. This is where you are going to use either the sandpaper or the nail polish remover to rub off the black coating. It will NOT rub off the red of the "Si" logo! That's the whole point :nod: Image
Grab your sandpaper or nail polish remover. I used some 400 grit sandpaper that can be bought for dirt cheap at any hardware store or Walmart. Use Home Depot, they're like the ricer emergency room... You want a MINIMUM of 400 grit, the higher the better! Image Image
Once you've sanded/nail polished off the area it should look like so.... Image
You can hold it up to the light to make sure you're hitting the right area... Image
The sun makes for a good "tester" of how your logo will glow. Image
Then just do everything in reverse order to put the cluster back together and re-install it. Be sure to clean any greasy fingerprints off the clear plastic overlay!
And here is the finished product. The logo will glow whenever you have your parking lights or headlights on. It looks especially bad-ass at night. Image
That's it, you're done. One small, cheap, simple mod :*) There ARE other variations of this... you can rig it up to glow when your vtec engages, you can sand down the black part in varying degrees to how you like the logo to shine, etc etc.
*on a side note, don't bother sanding behind ALL your lettering/numbering on your gauges...it looks like ass!
AIM = JoshuaVTEC
Post by munster » January 18, 2004
Very in-depth how-to. I never knew you could do that with an Si cluster. *thumbs up*
Post by kotomile » January 18, 2004
Hmmm... Innovative!
Post by .saint » January 18, 2004
thats a bad ass lil trick. :) very good how-to indeed.
Post by tenchu » June 06, 2004
Nice post :up:
TRAVASS
10% JDM
Post by TRAVASS » June 07, 2004
very in depth, i love D.I.Y.'s!!!
also while you have it all apart, just to be different, you can remove the "lil colored plates" over your indicator lights such as the green turn-signals, red ebrake, etc. i dont recomend removing the blue one for the high beams tho, because all these lights will shine white/clear instead of the origanal color... its kinda hard to see at night with the high beam light shining in your face! i did mine in my integra and in my CRX. Pretty sure you can do it to any honda or acura!
Project98EK
Post by Project98EK » May 21, 2005
haha i love this site, learn something new everyday
jdmgSix
Post by jdmgSix » June 15, 2005
<<i dont have an si cluster :( i cannot---sick diy though
89 was a good year.
...Lovin the Si
mcmBuilt
Post by mcmBuilt » October 30, 2005
Wow cool post, I did not know that :up:
