*The Complete Guide to Plastic Light Restoration*
https://thejdm.com/forum/viewtopic.php?f=59&t=1993
Author:  GSRstilez [ June 07, 2004 ]
Post subject:  *The Complete Guide to Plastic Light Restoration*
This guide will assist greatly in your road to re-finishing your dull, scratched, swirled, and/or oxidized lighting such as tail lights, corner lights, or headlights. Now, you can vary which products you use, but I hope you see the results I achieved with the ones present. What you will need is:
-Spray Bottle (Home Depot)
-Your Favorite Car Wash (Pep Boys or PAC)
-3 Towels (I prefer Microfiber from PAC)
-2 Applicators (I prefer Microfiber from PAC)
-A Aluminum Polish (I chose Mother’s from Wal-Mart)
AND/OR
-A Paint Polish (Like Meguiar’s #82 Swirl Free Polish from PAC)
-A Rubber Sanding Block (Ace Hardware)
-1500 Grit Wet-Sanding Papers (Ace Hardware)
-A Nylon Bristled Brush (Wal-Mart)
-A Protectant (I chose the Klasse Twins for their durability from PAC)
Image First off, you want to start by cleaning the lighting surface and inspecting it for damage. In the spray bottle, put 1oz of car wash and the rest water (low pressure), then tighten the bottle and shake up to mix. I used this mixture along with a microfiber towel to clean the surface. The best way to check for damage is to hold the surface into a bright light allowing the sourced lighting to reflect off what you are working with, in this case a tail light. This amplifies imperfections, and in this case, swirls were the main problem. However, there were a couple scratches in which I eventually removed.
Image Notice the haze over the suface...They are actually swirls
After you inspect, you could do 1 of 2 things. If your surface is pretty much flawless, I’d go straight to the polishing step, but since I had a couple scratches, the next step was to wetsand the lights down to level the surface. I took a sheet of 1500 grit wet-sanding paper and soaked it in a bucket with 1 gal water:1 oz car wash for 20 minutes. Next, I cut to fit the paper and mounted it on the sanding block. I then sprayed the taillight generously with the soap:water mixture to lubricate and began wet sanding. I went side to side which I found easiest using medium presure. DO NOT DO IT IN CIRCLES or PUSH HARD. I sanded for about 20 seconds each section (see pic) to level out the surface. I then sprayed down the light and wiped clean with my microfiber to inspect for a level surface. After inspecting, I finished up the remaining areas and went to the polishing stage.
Image Image Image
For the polishing stage, you want to remember this. Unlike paint, you need to let the polish do all the work here, not the heat you are producing. Plastic is much weaker to heat than a clearcoat is and it will burn easily. With this said, I applied the Mother’s Aluminum Polish generously on the surface. I then took my Makita Rotary w/ polishing pad at the LOWEST speed and polished til there was only a slight haze of product, then wiped clean with a new microfiber. I inspected the surface and repeated to insure a full polishing out of all the defects. Repeat if necessary. Now, if you just have a PC, then use a polishing pad on a low setting allowing the polish to do the work, just like I stated above. By hand, you will need to start off with a paint polish like Meguiar’s #82 SFP or #83 DACP applied with a cotton or microfiber applicator in the same way you wet-sanded, side to side. You don’t want to press to hard, remember, let the polish do the work. Work it until you have a light haze of product, then remove with your microfiber. Follow this up with an aluminum polish using the same technique to bring the lights to a deep, defect free gloss. With the detailing brush, you will want to gently brush any polish from the raised lettering in “Koito” or the other words so there is no white residue.
Image Image
After re-inspecting the surface under the light, you will want to protect your lighting from future dulling or oxidizing. The only way to protect them from scratching and swirling is to touch up your car-washing skills. Now for protecting, I chose the Klasse twins for their remarkable durability. I applied AIOx2 to insure all the oils from the polishes were removed, then SGx1.
Image Image Left is untouched, Right is after this full process
Image High Gloss and Defect Free!
This concludes the lighting restoration guide. Remember, this will work on any hard plastic lighting, but don’t attempt this on soft plastic windows. Any questions, post them back here. Good Luck!
Author:  kotomile [ June 07, 2004 ]
So good to have you around man, great info as always!!
One question though, how do you recommend washing microfiber cloths?
Author:  .saint [ June 07, 2004 ]
amazing. you are honestly the fucking man :up:
Thanks for the compliments.
kotomile: To wash microfibers, wash them separately from all other linens. Wash them on a warm regular cycle with regular detergent. If you use a lot of harsh cleaners with your MF's, squirt some Dawn in there and use a Downy ball (washed out) filled with Distilled White Vinegar. I usually do the extra rinse at the end to.
Dry them on delicate, low heat.
NO FABRIC SOFTENER.
Good Luck and remember to take the lights out to do this. Your results will make your time spent pay off!
Author:  kotomile [ June 08, 2004 ]
:blang: thank you!
Author:  g3teg97 [ February 26, 2006 ]
Does this apply to headlights?
Author:  Sean @ NDF [ February 26, 2006 ]
oldy but goody, yeah you can do this to headlights...imma do it soon to my old ones. good write up!
Yeah, I just realized after I posted, that the thread is almost 2 years old. I just bought some headlights so I'm thinking to give them a good cleaning while they're sitting in my room.
Author:  Secret Squirrel [ February 26, 2006 ]
ill be doing this to my tails
