.:How to wash your car without a hose:.
GSRstilez
Post by GSRstilez » February 01, 2004
That's right, wash your car without the use of a hose. This product is your answer to a lot of problems with washing. You can now just fill 2 buckets up with water from your sink (warm water) and do it in your driveway, workplace, or anywhere your heart desires. No problems...
The Product
Protect-All Quick & Easy Wash
Image This product is used by many RV owners and just works absolute miracles. It has a unique anti-static property that lift dirt and grime off the paint's surface without the need to hose the vehicle down first. It will not scratch or swirl your surface if used correctly and will not remove wax. You use almost nothing to get the job done and the price is great!
The Procedure
You will need:
-(2) 1-2 gal. buckets
-(2) Soft Cotton Chenille Wash Mitts
- 1 oz. of your favorite Quick Detailer (I used Meguiar's)
-(4) Small Terry Towels (100% Cotton)
-(2) Microfiber Towels
You will begin with bucket #1. In bucket #1, you use 1 oz. (2 capfuls) of QEW mixed with 1 oz. of your favorite QD (for extra lubricity) and 1 gal. of warm water. In bucket #2, you fill it up with straight warm water.
Next goes the washing. Now, unless your vehicle is considerably dirty, there is no need to hose your vehicle down. That's right, you take the wet mitt to the dry car [:o].
Anyways, you will be doing 1 panel at a time basically using My Car Washing Article. Say we start with the fender...Dip the first mitt in the QEW/QD solution and make sure it's saturated. Start at the top of the fender, move the mitt front to back (the way the wind moves over your car) and work down the fender overlapping your previous pass. If the fender is relatively dirty, flip the mitt over so you're washing with a clean surface. There is no need to use a lot of pressure at all. I usually use just the weight of the wet mitt[:D]. When the fender is done, toss the dirty mitt in bucket #2 (warm water) and run your hands over the mitt to loosen up any dirt. Grab mitt #2, dip it in the QEW/QD solution and go to your next panel. Repeat until finished.
Now, to dry... You will want to dry right after you wash each panel (ie: wash fender, dry fender, wash door, dry door, etc). To do this, first use a clean 100% Cotton Terry Towel and drag over the surface lightly to remove most of the excess water. Then use your Microfiber towel to buff off the excess dampness. Remember, always let the towels flow like the mitts (front to back, like the air flows over the surface).
Where to buy
Quick & Easy Wash is available at Camping World. That will be the best deal on the net (I've searched). Check out the product's homepage here.
The mitts, terry towels, microfibers, and QD are all available at your local Wal-Mart.
MAKE SURE when washing your linens after a wash... You can wash the mitts and terry towels together on a regular cycle with detergent. NO FABRIC SOFTENER. The terry towels can be dried in the dryer, but the mitts must be hung dry. The microfiber's should be washed on a delicate cycle with nothing but the detergent and the microfibers. When dried, hang drying or in the dryer on delicates is the best.
Pre-washing of the linens is reccomended before using
Pics
BEFORE Image AFTER Image Image That is 1 pass using only the pressure of the weight from the mitt.
Image Finished product.
Comments and Questions are welcomed. Please read this write-up and Protect-All's Webpage thoroughly before asking anything. Thanks and best of luck to ya!
Sean Busch
www.DetailingByExecutive.com
Post by BRYCE » February 03, 2004
huh.. Never would have thought to use buckets.
stinky
Post by stinky » February 04, 2004
DOES IT SCRATCH THE PAINT AT ALL?
i'm back!!!!!!!!!
GSRstilez
Post by GSRstilez » February 04, 2004
stinky wrote:DOES IT SCRATCH THE PAINT AT ALL?
C'mon...Would I use this stuff if it scratched or swirled the paint? Hell no. :haha: It has a unique Anti-Static property to it that lifts dirt and grime right off the surface. Use the instructions I have posted and you will be just fine.
Little words of wisdom...If your car is hideous, make sure you hit up the DIY Coin-Operated wash first to hose it down with their pressure washer, then use the spray soap, then back to the pressure washer. You want to be sure you go from top to bottom and don't forget the undercarriage. Then you will be safe to do the QEW. If you are unsure, look at the pics from when I did it to see if your car is TOO dirty.
Just follow the directions carefully and take your time. Your efforts will pay off.
I absolutely love this stuff because I live at college 8 months out of the year (no hose).
Good Luck!
Post by .saint » February 04, 2004
damn ill be looking into this when the car is in the garage :)
FerioLady
Post by FerioLady » October 18, 2005
wow that sounds cool. Where can i find that product ? i wanna try it out. :kitty:
TC
FiveOneO
