KA24DET
T3/T4 60 Trim
Peakboost Manifold
Custom Burns Stainless Down pipe with V-band
JE Pistons 8.5:1
Crower Rods
Cometic HP Head gasket
Hand ported head Stage 3 (Done by DPR)
Tial 35mm Wastegate
Z32 MAF
Ferrea Valve Spring and Retainers
Greddy FMIC (VSPL)
Custom Intercooler piping
HKS SSQV (First Gen Adjustable)
Magnicore 8.5mm Plug wires
NGK Iridium Spark Plugs Heat Rage 7
Gp sports Exhaust With V-Band
JWT Pop Charger
All New Gaskets
JWT Cams 275 Deg.
JWT Cam Gear
COOLING
Spal Fan
C&R Custom Dual Pass Radiator w/ surge can
New OEM Waterpump
All BMRS Lines
Drive Train
Spec Stage 3+ Clutch
Spec Flywheel
B&M Shortshifter
Powerslot 350Z Rotors (Front)
Tomei Technica Trac 2way
SS Brake Lines & Cluch line
Hawk HPS Brake Pads (front)
Project Mu D1 Rear Pads
Z32TT 30mm Front Brake Calipers
Fuel Delivery
Twin Walbro Intank Fuel Pumps 255 l/h (Hard Wired)
72lbs MSD Injectors
JGY Fuel Rail
Aeromotive FPR
Footwork
Silkroad Rear Camber Arm
Silkroad Rear Traction arms
Silkroad Rear Toe Arm
Tein Tie Rod
Tein Tension Rod
Nismo Power Brace
Peak Performance Subframe Bushings
Silkroad Coilovers
Electronics
Apex-i AVC-R
HKS Fan Controller
Autometer Phantom Oil Press, Boost, Watertemp, Fuel Press.
JWT ECU
Etc.
German Headlights (Glass)
HID (6000k)
Greddy Lip Spoiler
Enkei RPF1 18x9.5 +15 (SBC)
Circuit Sports Hood Dampers
Optima Redtop Battery (trunk mounted)
Sony Headunit
Spin turn knob
Greddy Ball Shift knob
NRG Thin Hub
NRG Quick Release
Nardi 350mm Deepcorn Wheel
New Starter
MSD Box Dig. 6
New OEM s14 harness
Project kics oil drain bolts
Project kics R40 Neo Chrome Lug nuts
Oil changed every 1500 miles with Mobil 1 15w-50 (Gold Cap)
Dif oil changed ever 3k with Torco Oil With Friction Modifier
Torco MTF in Tranny
ALL WORK DONE AT and BY ENJUKU RACING.
This car is amazingly built, the man hours alone in custom fabricated parts and wiring are worth thousands.
Grab it now for
12,500$ OBO!!!
If you have any questions feel free to PM me or catch me on AIM. My friend needs to sell the car because he is trying to start a family and needs to move on.
