| How can you tell if it's obd1 or obd2 ECU? https://thejdm.com/forum/viewtopic.php?f=52&t=4760 |
| Author: | sfc [ September 29, 2005 ] |
| Post subject: | How can you tell if it's obd1 or obd2 ECU? |
Just wondering how you can tell the difference. Are they visually different? Is there a serial number somewhere that you can tlel from? Trying to figure out whether this fucker is obd1 or obd2. This all stems from my IACV... the one I ordered is supposedly the part from an OBD1 car... So I'm thinking, either someone had to re-wire for obd1... or I dunno, just trying to figure out my CEL shit still. |
| Author: | Sean @ NDF [ September 29, 2005 ] |
check it out http://www.obdii.com/connector.html |
doesn't really help. No pics, no item numbers for civics :/ Thanks for trying though, e for effort. |
| Author: | Secret Squirrel [ September 29, 2005 ] |
smash it with a hammer.... SS |
| Author: | Nikku [ September 29, 2005 ] |
ODB-1
ODB-2the plug styles is way differet, now telling the difference between ODB-2a and ODB-2b is near impossible without tracing wires |
wow, mine is really a bastard child. The "plugs" if you will, look like the second picture, but the 3 left plug holes are the only ones with pins, the right most slot is empty. Go figure that one out?? I'm assuming it's obd-1 then? |
woopsie i was wrong, sounds like OBD-2b ![]() |
| Author: | munster [ September 29, 2005 ] |
Temp...sticky those pinouts in another thread. Katman rox. |
werd, katman is good. Sorry for my first post, it was a very hurried one |
| Author: | Nikku [ September 30, 2005 ] |
yessah he does, i will sticky it in the engine tech forum in a bit |
