| DOHC noise https://thejdm.com/forum/viewtopic.php?f=52&t=4661 |
Page 1 of 3 |
| Author: | badass88gt [ September 12, 2005 ] |
| Post subject: | DOHC noise |
Do dual overhead cam motors tend to produce more valvetrain noise then basic OHV motors? Is this common? |
the acura I used to have, 1.8 DOHC (1990) had been ran low on oil, and now it ticks. I called up josh (tenchu) he says it could be a knock, since its such a small engine, what I would think of as valve noise on a V8 could actually be a knock. What do you guys think? |
| Author: | sfc [ September 13, 2005 ] |
I think you shouldn't call tenchu for car help |
| Author: | Secret Squirrel [ September 13, 2005 ] |
[quote="sfc"]I think you shouldn't call tenchu for car help ] BUAHHAHAHAH SS |
| Author: | badass88gt [ September 13, 2005 ] |
from every engine that I ever worked with that knocked, it wasn't a constant sound until it was seconds away from blowing. This is a very constant tick tick tick sound, that occurs all throughout the rpm range. Looked under the oil cap with a flashlight, saw the cam was scored, dont know if that makes a difference but I would assume its not good. If it is in the head on the car, any suggestions to what it might be? cam bearings? |
| Author: | Nikku [ September 13, 2005 ] |
there are no cam bearings, you probably just need a valve adjustment |
| Author: | tenchu [ September 13, 2005 ] |
[quote="sfc"]I think you shouldn't call tenchu for car help ] I guess you don't know how many motors ive blown Take it to AAS bro, they should be able to help ya. |
| Author: | ls.pwrd.hb. [ September 14, 2005 ] |
hahahah but really if im pry sure you would be able to tell bye the sound if it was normal or not |
| Author: | sfc [ September 14, 2005 ] |
I do... which is exactly why I told him not to listen to you. Given that you COULDNT FIGURE OUT WHEN THE MOTOR WAS BLOWN IN THE FIRST PLACE. |
| Author: | tenchu [ September 14, 2005 ] |
Sure I couldn't thats why I had arangements for replacment as soon as it happened. Thanks |
