Brake light
https://thejdm.com/forum/viewtopic.php?f=52&t=4186
Author:  spdyslvrEX [ June 29, 2005 ]
Post subject:  Brake light
Alright so I did my brakes the other day and my dash brake light stays on.
You know the one that comes on when you have your E-brake on?
What should I do?
Author:  tenchu [ June 29, 2005 ]
Check your brake fluid. Also check that the the fuses are fine?
Author:  TRAVASS [ June 29, 2005 ]
I was gonna say check the fluid, but if thats not it check the switch at the actual handle.
Author:  .saint [ June 29, 2005 ]
mine stays on once in awhile. you might need to pop your console out and take a look at the harness. mine had a lil short in the wires i had to tape up. from pulling the ebrake tome after time it wore through the wires.
Author:  BRYCE [ June 30, 2005 ]
its the ebrake harness.
Author:  spdyslvrEX [ July 03, 2005 ]
Where is the Ebrake Harness? under the center console? 2001 EX.
