What about a TL/CL/RL forum?
Post by munster » February 03, 2006
:up: That's how this site started and got all of its members. Word of mouth. We were never out to break membership records...just provide a chill place to hang out.
Once I see alot more TL/CL specific posts being started...you'll see a section magically appear. :bang:
UnsanePyro
Post by UnsanePyro » February 04, 2006
Another TL member here 8)
BTW, you guys are missing an engine in your archive thread
Post by munster » February 04, 2006
UnsanePyro wrote:Another TL member here 8)
Welcome to thejdm.
What thread and what engine?
UnsanePyro
http://www.thejdm.com/forums/viewtopic.php?t=3204
That's the thread.
The engine:
G25A4
http://tl.acurazine.com/forums/showthread.php?t=124472 wrote:The 2.5 (engine code G25) is a unique inline five cylinder all-aluminium motor (with iron cast piston linings) with a single overhead camshaft and 4 valves per cylinder. Mounted longitudinally in the engine bay, this allows for better weight balance (60/40) than the traditional transverse mounting common in front wheel drive cars. In addition, the 2.5 motor is tilted 35 degrees allowing it to fit under the low hood and allows long intake runners for the dual stage intake. Above 5000 rpms, the 2.5 motor uses the shorter intake runners for high RPM breathing allowing for better passing power. Power is rated at 170 foot pounds of torque and 176 horsepower. However, dynos have proven the 2.5 to have a broad torque curve and excellent high RPM power. Its true power is in the 190 hp range. It is speculated that Honda did this so it would not infringe on the Legend and later, its brother the 3.2 TL.
Fixed. Thanks for the info.
