wtf is wrong with my blazer?
sfc
15% ricer
Post by sfc » December 06, 2004
Since robry sucks and can't help at all :) The thing just will NOT idle right now. I'm pretty sure this all started after I put some injector cleaner into it (it sat for 6 months I figured it'd probably be good to clean the injectors a bit). It's a 93 s10 blazer, 4dr 4wd. Anyways, the thing like idles like it's got some freak ass lobey (sp?) cam in it... just VWOOM *almost dies* VWOOM *almost dies* VWOOM. If I try and idle with it in gear it will die unless I keep the gas peddle pressed a bit. And if I'm accelerating at all it's smooth as hell... so basically it's only an idling problem... any ideas? It doesn't spit an engine code most of the time, although sometimes after driving for like half an hour it'll spit a SES (service engine soon). But as soon as I shut the truck off and restart it that's gone.
Post by .saint » December 06, 2004
maybe a vac. line? check the plugs and wires as well.
just teg'n it
70% ricer
Post by just teg'n it » December 06, 2004
i'd say vacuum as well.
Post by BRYCE » December 06, 2004
ya vaccumm 95% of the time
Post by tenchu » December 06, 2004
Vaaacume lines :down:
sfc
15% ricer
Post by sfc » December 07, 2004
k, will check. The thing started running normal again last night too... I'll check though if it's being a biatch again tonight when I go to class.
just teg'n it
70% ricer
Post by just teg'n it » December 07, 2004
damn small block chev's they are all the same :roll:
sfc
15% ricer
I dunno... it's at 200k miles, and other than this possible vacuum line it's got no issues. Doesn't burn any oil or anything... I'd say that's doing allright.
Bangin HB
90% ricer
Post by Bangin HB » December 07, 2004
4.3 TBI? one thing that will really clean up the idle is changing the pcv valve. get some of that spray carb cleaner and a new valve. take old pcv off (side of TB), spray some carb cleaner in the soft line and into the tb (with engine running. small squirts at a time) then put your new valve on the line and stick into hole. wouldnt believe how much it helps, plus its cheap. before and after idle was like 2 dif engines.
^clicky for the NEW all hatch community: e-hatch
