Munster's Winter Thread.
Post by munster » October 23, 2006
Well...it's getting that time. Betty's almost ready to be parked. Maybe one or two visits to the track to get some cool weather passes out of the LS before it's yanked. Figured I'd throw a thread together to keep a checklist for myself and give you guys something else to read other than some whore threads.
Here's the plans as of right now:
B18C block.
84mm bore
GE sleeves
89mm stroke
Head is undetermined right now.
GT35R turbo
Top Mount manifold (unsure of brand. Taking opinions.)
Full Race traction bar.
Finally put my rear discs on.
rear lower tie bar
Function/Form coilovers
Quaife LSD in my GSR tranny and make sure everything's kosher inside. (third has a crunch to it already)
Clean up the bay, tuck some wires, put in a vac manifold, change over some lines to braided stainless steel.
fuel rail, fuel pressure regulator, up the voltage to my fuel pump, and possibly a larger feed line (8AN or so). See where my fuel is when it gets tuned when it's all done.
Plans are to see what she's got in the spring. If they throw me out for no cage...I'm where I want to be. Then I can worry about a cage if I want to keep it at that level. We'll see. I really should learn how to drive 260whp, though. hahaha. We'll see if I can get the elusive 12.5 on 10psi before the snow lays.
Post by Sean @ NDF » October 23, 2006
YES! another buildup thread...I love these
miyagi
Post by miyagi » October 23, 2006
can't wait to see it all done munster it's gonna be sick! :twisted:
Maybe i'll make myself a winter build thread too ... my car is gonna take a mild transformation over the next few months as well 8)
Edit -
I was looking at the function/form coilovers as well... i might pick up some koni yellows and ground controls instead though.
Also - munster... you, duanne and myself all have the same mentality about the cage issue. I'm not going to get one till they tell me not to come back unless there's one in there. Then i'll just look at them with a smile on my face and ask if i can just turn the boost down instead :P
1990 Accord EX Sedan
All stock, All the time
money in the baaaank
I just don't want to deal with the other issues that come with a cage. The rigidity just killing parts. I'll work up to it. I'm sure it's eventually going to be caged. Possibly even next year.
Post by 77 » October 23, 2006
Rockin'.
I♥CarFriends!
miyagi
munster wrote:I just don't want to deal with the other issues that come with a cage. The rigidity just killing parts. I'll work up to it. I'm sure it's eventually going to be caged. Possibly even next year.
agreed. I don't really feel like snapping axles like its no one's business ... especially because when my car runs and its not snowing, it's daily driven.
vtecdood
Post by vtecdood » October 23, 2006
Cages are for steers and queers and this aint texas.
Sounds like a killer combination in mind cant wait to see the numbers you'll have some time till you will need cage you'll make a ton or hp and torque it will take time to get your launch down I'm still trying to figure mine out hahaha......
vtecdood wrote:Cages are for steers and queers and this aint texas.
I'm figuring that it'll be most of the summer with very high trap speeds and horrible ETs.
Post by boostjunkie95 » October 24, 2006
Betty is going to be baller even when shes running 14.50's @ 130mph. :up:
Post by BRYCE » October 24, 2006
sounds like a great right plan!
