| WV hatch build https://thejdm.com/forum/viewtopic.php?f=31&t=10840 |
| Author: | Rogue [ May 09, 2010 ] |
| Post subject: | WV hatch build |
HI friends lets start with what it looked like before i decided to go a total 180 on the plans i did have for it.
then i decided i wanted to go turbo and actually finish spraying the entire car.
| Author: | .saint [ May 09, 2010 ] |
| Post subject: | Re: WV hatch build |
welcome homie like i said the traffic around here isnt the greatest anymore but in time it will blow back up haha. love this build cant wait for more updates |
| Author: | spnfedeg6 [ May 09, 2010 ] |
Welcome Rogue, you finally joined!! |
the new B18A1 Block: All machine work was done at Laskey Fully Blueprinted 84.5mm Bore Benson Sleeved CP 9 to 1 Pistons Eagle H Beam Rods Fluidamper Harmonic Balancer Micropolished and Balanced Crank ACL Race Bearings Moroso Oil Pan Type R Water Pump Type R Oil Pump and Pickup Toda Timing Belt B&R Block Fittings
b16A2 Head:Supertech Nitride Coated Flat Faced Valves Supertech Dual Valve Springs Supertech Aluminum Retainers Supertech Keepers Supertech Bronze Valve Guides Supertech Valve Seals Skunk2 Pro1 cams str/bdl cam gears port work done by advanced motorwerks 3 angle valve job resurface and bead blast edelbrock intake str 68mm tb
| Author: | Jams_ek [ May 09, 2010 ] |
nice setup bro welcome to thejdm! |
| Author: | ap_red97ek [ May 09, 2010 ] |
welcome man. I like everything about that car before you decided to respray it, except the wheels, just not my style but everything else is sweet! |
| Author: | munster [ May 09, 2010 ] |
Welcome. I've followed this build on a few sites. |
| Author: | .saint [ May 10, 2010 ] |
the work in that bay is insane |
| Author: | Teaks92HB [ May 10, 2010 ] |
Very nice!! |
