| help https://thejdm.com/forum/viewtopic.php?f=26&t=10699 |
| Author: | robopat [ September 13, 2009 ] |
| Post subject: | help |
hey guys I bought a JDM gauges for my 04 accord,by the way if anybody cares the jdm tsx 04-07 gauges are the same as the usa accord,everything works and looks good but the airbag light stays on ,any help on this wuold be great.Thanks. |
| Author: | tenchu [ September 13, 2009 ] |
| Post subject: | Re: help |
First thing first you check al your fuses? Reset your ecu? |
| Author: | .saint [ September 13, 2009 ] |
pull the bulb? lol. ground and everything between the cluster and the harness the same? |
lol... cmon jon, its the AIRBAG not the check engine light, lol... you got the yellow plug hooked up to the harness? |
yeah the SRS light, mines on in my civic because i pulled the entire srs unit. if the plugs are different on from the accord to the tsx cluster its going to put the light on, its a warning light letting you know the srs unit is not functional. |
ARE not the fuses cause I put the old one back and the light goes off,how do I reset the ecu?,there is only one big green plug they look the same ,although the jdm cluster has a small plug next to the big one.thanks all for the help |
the SRS wiring is 99% of the time yellow in all cars. i know in all honda's its yellow. any pictures of the back of the cluster? |
I know about the yellow wire but here is only one harness I`ll get same pictures. |
As Jon said, the SRS plug is 99% of the time yellow, like such:
If you have a small opening, thats probably where the SRS plug goes |
If your sure its not the fuse, i'd take it to AutoZone and have them scan your ECU for free, then they can reset it for you too. |
